Windows 7 List of Voice Control Comands.
redhotfusion
do any of you have a good list of Voice control comands.
Thanks
When it comes to voice control commands, particularly for Windows, there are several useful voice commands you can use to navigate, control apps, and interact with your system. Here is a list of common voice control commands for Windows:
Common Voice Control Commands for Windows:​
| Command | Description |
"Hey Cortana"Activates the Cortana voice assistant.
"Open [App Name]"Opens a specific application.
"Close [App Name]"Closes the specified application.
"Minimize" or "Maximize"Minimizes or maximizes the current window.
"Switch to [App Name]"Switches to a specific application.
"Scroll Up" or "Scroll...
"Scroll Up" or "Scroll Down"Scrolls the content on the screen.
"Turn Off" or "Shut Down"Initiates the shutdown of the system.
"Lock PC"Locks the computer screen.
"Sign Out"Signs out of the current user account.
"Show desktop"Minimizes all windows to show the desktop.
"Open settings"Opens the Windows settings.
"Take a screenshot"Captures a screenshot of the current screen.
"Open File Explorer"Launches the File Explorer for file navigation.
"Search the web for [Search Query]"Conducts a web search using the default browser.
"Set a reminder for [Reminder]"Creates a reminder for a specific task.
These commands can be used with voice assistants like Cortana on Windows to enhance your productivity and control over your system. Feel free to explore more commands based on your specific needs or preferences.
