Windows 7 log on problem
Pauli
I'm not sure I understand you, but usually when you log in, it happens that your username and / or password comes out as ******* or something. Usually ones username comes out correctly, like mine here "Titanic", but the password shows as **************.
It goes for all sites. It's a matter of your security. No problem if you're a person, but all the problems if you're a bot.
