Windows 7 Login with RemoteDesktop WITHOUT exit remote session possible?
pstein
Assume a remote user (needing help) is logged in at a remote computer.
Now I am connecting from local computer to the remote computer by using the built-in RemoteDesktop Tool
and using his login account (password known).
At the moment when I login the session on the remote computer is automatically closed. the remote user cannot see anymore what I am doing.
Can I change this?
Can I connect through RemoteDesktop tool and let the remote user stay in his session?
I don't want to create a second account but use the remote users account.
Other remote desktop tools (e.g. TeamViewer) can handle this.
So it should be possible with RD as well....
Peter
As far as I know, what you seem to want to do is called "Shadow the Console Session" and as i recall this is only possible using Windows Server running Terminal Services.
So your best bet is to stick with something like TeamViewer as you've mentioned above.
Trouble
Noob Whisperer
