Windows 7 Lower in 8
Drew
Banned
Put a CPU gauge, like the All CPU Meter (gadget) not, the silly thing that is in the default Gadgets offering on the Desktop in a dual-boot set up w/ 7 & 8. Go back & forth between the 2 OSs, do the same sort of tasks & activities on each. You will see the resource usage is significantly & substantially lower in 8 than, 7.
To compare resource usage between Windows 7 and Windows 8 on a dual-boot setup, you want to monitor CPU usage using a CPU gauge similar to the All CPU Meter gadget. However, since gadgets are not supported in newer versions of Windows, you'll need to find an alternative CPU monitoring tool that works on both Windows 7 and Windows 8. One popular and versatile tool that can be used for monitoring CPU usage is Rainmeter. Rainmeter allows you to customize your desktop with various widgets, including CPU monitors. Here's how you can set up a CPU monitor using Rainmeter on both Windows 7 and Windows 8: 1. Download Rainmeter: - Visit the Rainmeter website at https://www.rainmeter.net/ - Download and install Rainmeter on both your...
To compare resource usage between Windows 7 and Windows 8 on a dual-boot setup, you want to monitor CPU usage using a CPU gauge similar to the All CPU Meter gadget. However, since gadgets are not supported in newer versions of Windows, you'll need to find an alternative CPU monitoring tool that works on both Windows 7 and Windows 8. One popular and versatile tool that can be used for monitoring CPU usage is Rainmeter. Rainmeter allows you to customize your desktop with various widgets, including CPU monitors. Here's how you can set up a CPU monitor using Rainmeter on both Windows 7 and Windows 8: 1. Download Rainmeter: - Visit the Rainmeter website at https://www.rainmeter.net/ - Download and install Rainmeter on both your Windows 7 and Windows 8 installations. 2. Find a CPU Monitoring Skin: - After installing Rainmeter, you can search for CPU monitoring skins on the Rainmeter website or other skin repositories like DeviantArt. 3. Install the Skin: - Download the CPU monitoring skin you prefer. - Double-click the downloaded .rmskin file to install the skin in Rainmeter. 4. Configure the Skin: - Right-click on the Rainmeter icon in the system tray. - Navigate to the skin you installed and customize it to display CPU usage the way you prefer. 5. View CPU Usage: - The installed skin will display real-time CPU usage on your desktop. You can monitor how your CPU is being utilized in both Windows 7 and Windows 8. By using Rainmeter with a CPU monitoring skin, you can observe and compare the CPU usage between Windows 7 and Windows 8 as you switch between the two operating systems and perform various tasks and activities. Keep in mind that Windows 8 may have optimizations and improvements that could result in lower resource usage compared to Windows 7 for the same tasks and activities.
Content Advisory 67%
This content may target or intimidate individuals in ways that violate our community guidelines.
Primary concern: Harassment
We encourage constructive discussion while maintaining respect for all community members.
AI Content Assessment · May 21, 2025
