Windows 7 making a noise after coping or moving files are done
franktheman7
Well-Known Member
How can I make a noise after coping or moving files are done on my pc
TIA
Frank
I don't believe that Windows has a built in hook for this type of sound trigger. If this is something your copying consistently then its possible to use a script that plays a sound when its completed, if you want it to happen on every file copy your going to have to find a file copy replacement program that supports sounds. I looked at a few including TetraCopy and Ultracopier but did not see a sound feature. Ultracopier has source so one could recompile it to add a sound feature, or request that the author adds such a feature.
Josephur
Windows Forum Admin
