It seems like you're facing compatibility issues with your Pinnacle PCTV Remote Kit on Windows 7. Here are some steps you can try to troubleshoot and potentially fix the issue: 1. Driver Update: - Make sure you have the latest drivers for the Pinnacle PCTV Remote Kit compatible with Windows 7. You can check the Pinnacle website for driver updates specific to Windows 7. 2. Compatibility Mode: - Try running the driver installation and any associated software in compatibility mode for Windows Vista. Right-click on the installation file, go to Properties, and then set the compatibility mode to Windows Vista. 3. Device Manager: - Check the Device Manager to see if the remote kit is recognized or if there are any errors...
