MEMORY_MANAGEMENT Error in BSOD
Hello, I have had many problems with the MEMORY_MANAGEMENT BSOD in the past. So I reinstalled Windows, ran all the updates and such, and I randomly got a Blue Screen that said "MEMORY_MANAGEMENT" as the error. Please Help!
"Scorpio"PC Specs:
MSI NF980-G65 (AMI BIOS is at ver 1.20, scared to update to 1.40)
AMD Phenom II x955 Black Edition Quad Core
4gb(2x2gb)Corsair XMS3 DDR3 RAM @ 1333Mhz
EVGA GeForce GTX 260(Regular)
Corsair AX1200 1200 Watt Power Supply
Windows 7 Ultimate 64-bit
Heres the minidump folder, I've had only two BSOD's. They both held the same error.
Please Help!
View attachment Minidumps.zip
usasma
Fantastic Member
Please provide this information so we can provide a complete analysis: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html
At work we run diagnostics on every system that we take in for repair (before we even start working on it). At a minimum, please run the free diagnostics here: Initial Hardware Diagnostics. For more in-depth diagnostics, please run those listed here: Hardware Diagnostics
Remove the wireless USB XBox controller software, then physically remove the device from your system to test.
xusb21.sys Wed Apr 8 10:28:44 2009 (49DCB49C)
XBox USB wireless controller [br] BSOD issues in Win7 with 2009 driver (found in mid-2012)
http://www.carrona.org/drivers/driver.php?id=xusb21.sys
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Tue Jan  1 10:11:35.434 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010113-22296-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:10:30.637[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+35133 )[/B]
BugCheck [B]1A, {3452, 77126000, fffff70001080790, 86100001e2604424}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000001A"]MEMORY_MANAGEMENT (1a)[/URL]
Arguments:
Arg1: 0000000000003452, The subtype of the bugcheck.
Arg2: 0000000077126000
Arg3: fffff70001080790
Arg4: 86100001e2604424
BUGCHECK_STR:  0x1a_3452
PROCESS_NAME: [B]conhost.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_3452_nt!_??_::FNODOBFM::_string_+35133[/B]
  BIOS Version                  V1.2
  BIOS Release Date             12/15/2009
  Manufacturer                  MSI
  Product Name                  MS-7612
**************************Tue Jan  1 09:58:28.724 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\010113-21093-01.dmp]
System Uptime:[B]0 days 6:20:24.943[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VIDMM_PROCESS_HEAP::Free+a2 )[/B]
BugCheck [B]1A, {403, fffff6800012abe8, 88d00000c794284f, fffff68000122be8}[/B]
Arguments:
Arg1: 0000000000000403, The subtype of the bugcheck.
Arg2: fffff6800012abe8
Arg3: 88d00000c794284f
Arg4: fffff68000122be8
BUGCHECK_STR:  0x1a_403
PROCESS_NAME: [B]bf3.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1a_403_dxgmms1!VIDMM_PROCESS_HEAP::Free+a2[/B]
  BIOS Version                  V1.2
  Manufacturer                  MSI
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]xusb21.sys                  Wed Apr  8 10:28:44 2009 (49DCB49C)[/B][/COLOR]
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
nvmf6264.sys                Thu Aug 12 07:46:06 2010 (4C63DEFE)
MpFilter.sys                Thu Aug 23 19:03:14 2012 (5036B6B2)
nvlddmkm.sys                Tue Oct  2 14:21:13 2012 (506B3099)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=nvmf6264.sys
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
Thank you so much, Usama. I managed to update the drivers and not a single BSOD since!
