This game, released May 14th, looks very interesting. Sequel to Metro 2033 you play the same character Artyom. The graphics look really impressive:
Picking up where 2033 concluded, Last Light follows the continuing exploits of Artyom, an elite soldier fighting for the survival of his faction in the city’s living, breathing metro system (to say more would spoil the enthralling story). On a technical level, Last Light is leaps and bounds beyond 2033, increasing texture quality through the use of incredibly detailed 2048x2048 textures, and geometric detail through the use of extra environmental and object-based tessellation. And like its predecessor, Metro: Last Light also features hardware-accelerated Link Removed that enable the realistic destruction of scene objects during combat, and the enhancement of other game elements, like particle effects.
Minumum System Requirements
  • Windows: XP (32-Bit), Vista, 7 or 8
  • CPU: 2.2 GHz Dual Core e.g. Intel Core 2 Duo
  • RAM: 2GB
  • Hard Disc Space: 7.5 GB
  • Direct X: 9.0c
  • Graphics Card: DirectX 9, Shader Model 3 compliant e.g. NVIDIA GTS 250 or higher
  • For 3D Vision Support:
    • GeForce GTX 275 or higher
    • 120Hz Monitor
    • NVIDIA 3D Vision kit for Windows Vista, 7 or 8
Recommended System Requirements
  • Windows: Vista, 7 or 8
  • CPU: 2.6 GHz Quad Core e.g. Intel Core i5
  • RAM: 4GB
  • Direct X: 11
  • Graphics Card: NVIDIA GTX 580 / GTX 660 Ti or higher
    • GeForce GTX 580/660 Ti or higher
    • 120Hz Monitor
Optimum System Requirements
  • CPU: 3.4 GHz Multi-Core e.g. Intel Core i7
  • RAM: 8GB
  • Direct X: 11
  • Graphics Card: GeForce GTX 680 SLI / GeForce GTX 690 / GeForce GTX TITAN
    • GeForce GTX 680 SLI / GeForce GTX 690
    • 120Hz Monitor
Ref:
Metro: Last Light Now Bundled With GeForce GTX Graphics Cards | GeForce
The game you are referring to, Metro: Last Light, seems to be quite captivating, especially with its impressive graphics and continuation of Artyom's story from Metro 2033. Here is a summary of the system requirements provided for the game:
System Requirements:​
| | Minimum | Recommended | Optimum |
OSWindows: XP (32-Bit), Vista, 7 or 8Vista, 7 or 8Vista, 7 or 8
CPU2.2 GHz Dual Core e.g. Intel Core 2 Duo2.6 GHz Quad Core e.g. Intel Core i53.4 GHz Multi-Core e.g. Intel Core i7
RAM2GB4GB8GB
Storage7.5 GB7.5 GB7.5 GB
RAM2GB4GB8GB
DirectX9.0c1111
GPUDirectX 9, Shader Model 3 compliant e.g. NVIDIA GTS 250 or higherNVIDIA GTX 580 / GTX 660 Ti or higherGeForce GTX 680 SLI / GeForce GTX 690 / GeForce GTX TITAN
3D Vision SupportGeForce GTX 275 or higher (120Hz Monitor, NVIDIA 3D Vision kit for Windows Vista, 7 or 8)GeForce GTX 580/660 Ti or higher (120Hz Monitor, NVIDIA 3D Vision kit for Windows Vista, 7 or 8)GeForce GTX 680 SLI / GeForce GTX 690 (120Hz Monitor, NVIDIA 3D Vision kit for Windows Vista, 7 or 8)
It's essential to ensure that your system meets at least the recommended requirements for a smooth gaming experience. If you want to enjoy the game with the best graphics and performance, aim for the optimum requirements. You can find more information about the game and its requirements on the http://www.geforce.com/whats-new/articles/metro-last-light-bundle. The YouTube link you provided seems to showcase the gameplay or features of the game, adding to the excitement around it. If you are considering playing Metro: Last Light, make sure your system is equipped to handle the demands of the game for an immersive experience. Enjoy your gaming adventure!
