NotGLaDOS
I haven't been updating my windows for a while so decided to do it today. However when I finished the latest one, I was met by this:
Is it meant to do this? What can I do to get rid of this?
Thanks,
Oliver
Sorry for being unclear or posting in the wrong area.
You have Windows 8.1 Update 1 installed.
What you see in your Start screen is the current version.
The " this person's metro " is the old version, prior to Update 1.
davidhk129
NotGLaDOS
No. What it normally does when I right click is have all the options pop up along the bottom. I have never seen this menu other than in desktop mode. Sorry if I'm explaining this badly.
In this persons metro, they have the options at the bottom... :confused:
davidhk129
NotGLaDOS
Ok thanks. Have just been doing some updating so that explains it. Shame though. How do I close a post? Or don't I? Do I just leave it? Sorry. :)
davidhk129
We cannot "close" a thread.
If you are done with it. Just "walk away".
If you are satisfied with my reply/answer, there is a " Best Answer " button at the bottom of each reply.
You can click it to indicate your acceptance of the reply.
You are not obligated to do so.
