Windows 8 Metro SSH client
numetheus
Does anyone know of a good SSH client for metro? Using the modern app look at feel? Would be great to scroll through a bunch of tiled consoles left and right. Currently using cygwin, but want to use Windows 8 style apps.
If you're looking for a modern SSH client that fits the Windows 8 style apps (formerly known as Metro apps), there are a few options you can consider. Here are some SSH clients that offer a modern look and feel similar to Windows 8 style apps:
Modern SSH Clients for Windows:​
| SSH Client | Description |
Windows TerminalWindows Terminal is a modern terminal application that allows you to access multiple command-line tools, shells, and SSH connections in one window. It supports customization and has a clean interface.
Windows Subsystem for Linux (WSL)If you're comfortable with using Linux distributions, you can utilize WSL to run a Linux environment directly on...
Windows Subsystem for Linux (WSL)If you're comfortable with using Linux distributions, you can utilize WSL to run a Linux environment directly on your Windows machine to access SSH.
MobaXTermMobaXTerm combines a plethora of network tools and security features into a single portable tool. It has a tabbed interface for multiple sessions, including SSH connections.
TermiusTermius is a cross-platform SSH client with a sleek, modern interface. It offers features like end-to-end encryption, server organization, and a unified experience across devices.
These options should provide you with a modern SSH client experience while maintaining the style you're looking for. You can explore them further to see which best suits your preferences.
