Microsoft’s In‑Box Low Latency USB Audio ASIO Driver for Windows on Arm
Microsoft has confirmed work on a brand-new, in-box low-latency USB Audio Class 2 driver for Windows on Arm that exposes a native ASIO interface and is being developed in partnership with Qualcomm and Yamaha — a move that aims to remove a long-standing friction point for musicians and audio professionals using Arm64 Windows devices.
Laptop runs Windows on ARM with audio software, connected to a USB audio interface by neon blue lines.Background​
For decades, professional audio on Windows has relied on the ASIO (Audio Stream Input/Output) protocol to achieve the low round‑trip latencies needed for real‑time recording, monitoring, and performance. ASIO drivers have typically been provided by audio interface vendors as custom kernel drivers, because the general-purpose in‑box USB audio stack shipped with Windows prioritized broad compatibility, battery life, and robustness over tiny buffer sizes and high channel counts. That has left musicians on newer Windows platforms — and particularly Windows on Arm — dependent on third‑party or vendor‑supplied drivers to get studio‑grade latency and features. Microsoft’s engineering team has publicly described a project that builds a new USB Audio Class 2 driver for Arm64 Windows devices, exposing both the internal WaveRT endpoint used by Windows and a native ASIO interface so DAWs can use the hardware directly. The company says previews will be available during 2025 and that the initial target is Arm64 devices, with x86-64 support to follow once the Arm64 implementation reaches the required quality bar.
What Microsoft announced (technical overview)​
The driver and its capabilities​
  • The driver will be a USB Audio Class 2 class driver that offers:
  • Support for devices currently supported by the existing USB Audio Class 2 implementation.
  • An option or mode optimised for low-latency musician scenarios and high I/O counts.
  • A native ASIO interface so that DAWs and other professional audio software can access hardware with minimal intermediate buffering.
  • The implementation follows the ACX framework for modern Windows driver development and is intended to provide:
  • WaveRT endpoints for standard Windows audio clients,
  • An ASIO interface for DAWs, and
  • Robust handling of power-management events on new Arm CPUs (important for laptops and mobile form factors).
  • Microsoft has promised to release the class driver source on GitHub, mirroring its approach with the new MIDI work — a move designed to help hardware vendors and the community learn from the implementation and contribute improvements.
Partners and vendor alignment​
Microsoft says the project is being developed in collaboration with Qualcomm and Yamaha (Yamaha/Steinberg), and multiple major audio vendors are already releasing Arm‑native drivers and previews. Notable examples publicized around the same timeframe include vendor previews and native Arm64 drivers from companies such as Focusrite and Steinberg.
Timeline and release expectations — parsing the signals​
Microsoft’s DevBlogs post clearly states previews will appear through 2025, and that the first delivery target is Arm64, with x86‑64 to follow. The company did not hard‑commit to a retail shipping date in that post; rather, it committed to shipping the in‑box driver in Windows once quality goals are met and the driver is ready. Some coverage and industry timelines tie the in‑box driver rollout to broader Arm Windows platform updates and new Arm silicon launches in early 2026. Reports about Windows 11 version 26H1 and next‑generation Snapdragon/NVIDIA Arm platforms expected in the first half of 2026 have led outlets to speculate that broader in‑OS delivery — or OEM OEM preload — might fall in early 2026 for retail systems running the new platform builds. Those timelines are driven by hardware launches and Windows image refresh schedules rather than an explicit Microsoft commitment that the driver will only be available in 2026. In short: Microsoft promised previews in 2025 and an in‑box ship when ready; independent outlets have reasonably tied full retail availability to the 2026 silicon and OS refresh cycle, but that is still partly speculative.
Why this matters: practical implications for musicians and producers​
1. Easier plug‑and‑play with professional gear​
If Microsoft’s in‑box driver functions as described, musicians will be able to plug many USB Audio Class 2 devices into an Arm64 Windows machine and get immediate ASIO‑level access without installing vendor kernel drivers. That removes steps that previously required locating vendor downloads, running installers, and dealing with driver compatibility woes. The result should be a drastically improved out‑of‑box experience for performers and field engineers using Arm laptops.
2. Reduced driver fragmentation​
By publishing a high-quality, open class‑driver implementation and the source code, Microsoft intends to reduce the need for bespoke kernel drivers from hardware vendors for basic functionality. Vendors can still ship optimized drivers for the last drop of latency or specialized features, but baseline compatibility should be much broader. This is important for long‑tail and legacy devices where vendors historically didn’t update drivers for new platforms.
3. Better multi‑app workflows​
Microsoft’s driver design contemplates scenarios where Windows and a DAW can use the same interface at the same time — something that many existing ASIO drivers achieve today. That improves workflows where live monitoring, system audio, or streaming software needs concurrent access to the audio interface.
Strengths and likely benefits​
  • Native ASIO access in-box: This removes a large usability and compatibility barrier for creatives moving to Arm64 Windows machines. Software that relies on ASIO (DAWs like Cubase, Reaper, and others) will be able to access devices directly without third‑party wrappers.
  • Vendor collaboration: Working with Qualcomm and Yamaha positions the project to be hardware‑aware (power management, DMA behaviour, SoC USB controller quirks) — improving stability and performance on mobile Arm silicon.
  • Open class driver source: Publishing the class driver on GitHub offers transparency, encourages vendor contributions, and can accelerate ecosystem adoption and testing. This lowers the barrier for smaller manufacturers and hobbyist device makers.
  • Vendor Arm64 drivers already arriving: Major vendors (e.g., Focusrite and Steinberg/Yamaha) have signalled Arm64 support and released previews or native drivers, smoothing the transition in the hardware ecosystem. These moves reinforce the idea that Microsoft’s in‑box driver is part of a wider industry shift.
Risks, limitations, and open questions​
Timing and delivery uncertainty​
Microsoft committed to previews in 2025 and Arm64 as the first target, but an exact retail shipping date has not been specified. Industry reporting that ties full retail availability to 2026 OS/silicon refreshes is plausible, but not guaranteed. Anyone planning projects or purchases on a strict timeline should treat 2026 availability as probable but not definitive.
Latency vs battery life tradeoffs​
Small audio buffers and high I/O counts raise CPU load and power draw — a particular challenge on battery‑sensitive Arm laptops. Achieving sub‑millisecond or single‑digit millisecond round‑trip latency without unacceptable battery drain or thermal throttling requires careful tuning at the driver, OS scheduler, and SoC power management layers. Microsoft acknowledges these tradeoffs and aims to expose low‑latency options, but vendors and users will have to balance latency against battery life.
ASIO is not a panacea​
ASIO provides low-latency access but does not handle device aggregation, advanced routing, or some modern multi‑client scenarios natively. Microsoft’s team explicitly noted these limitations and signalled that further API or driver work would be needed to cover advanced scenarios. For complex professional rigs, vendor drivers with custom features will still be important.
Vendor-specific optimisations will still matter​
Custom kernel drivers and vendor control software can still deliver performance and features beyond a generic in‑box class driver — for instance, firmware‑assisted monitoring, DSP, or special routing. That means users chasing the absolute lowest latency or special feature sets will still look to vendor drivers. Early vendor Arm64 releases (Focusrite, Steinberg) show that the industry expects to ship optimized vendors drivers in parallel.
Compatibility with plugins and DAWs​
DAWs and plugin ecosystems are heterogeneous. Some plugins, especially legacy x86/x64 binaries, will run under emulation layers or Arm64EC shims, but compatibility is not universal. Host and plugin vendors need to validate on Arm64; Microsoft’s driver is one piece — full DAW/plugin verification remains a downstream task for developers. Steinberg and others are actively working on Arm64 versions of major DAWs, which is promising, but the plugin compatibility matrix will take time to stabilise.
Driver signing, update cadence, and security​
An in‑box kernel driver becomes part of the platform surface area for security and stability. Microsoft’s in‑box approach centralizes updates (Windows Update) but also means any driver bugs potentially affect many users. Ensuring fast, secure delivery and an efficient update path for vendor‑specific optimisations remains essential. The plan to publish source code helps transparency but does not replace the need for a strict validation and update process.
What this change means for hardware manufacturers and DAW developers​
  • Hardware vendors can still ship optimized Arm64 drivers for their premium interfaces, but the pressure to provide a baseline Arm‑native driver is reduced. Focusrite and Steinberg have already provided previews or drivers that point to industry alignment. Vendors will benefit from Microsoft’s example driver and published source code as a compatibility reference.
  • DAW developers can rely more on a consistent in‑box ASIO endpoint on Arm64 devices, lowering friction for users. However, developers who aim to deliver the absolute lowest latency or specialized routing features may still want to maintain vendor-specific integrations or recommend vendor drivers where available. Early Arm64 previews of major DAWs demonstrate developers are moving toward native support, easing plugin and host compatibility testing.
Practical guidance: preparing for the transition (checklist)​
  • Inventory current audio gear and confirm whether the interface is USB Audio Class 2 compliant. Class‑compliant devices are the primary target for the new in‑box driver.
  • When evaluating new Arm64 systems for audio work, prioritize devices with proven high-performance SoCs (for example, Snapdragon X‑class chips) and robust cooling. The SoC and thermal solution matter for sustained low-latency workloads.
  • For mission‑critical setups (live shows, broadcast), keep vendor‑supplied drivers and test them thoroughly under the exact Windows build and hardware you plan to deploy. Even with a high-quality in‑box driver, vendor drivers can deliver the last mile of reliability and features.
  • Validate DAW and plugin chains on Arm64 early: install preview drivers and Arm64 DAW builds where available, and measure round‑trip latency, CPU load, and stability under real use cases.
  • Watch for the Microsoft driver preview releases in 2025, test them in a controlled environment, and provide feedback to vendors and Microsoft early in the process.
Developer and community opportunities​
  • The GitHub release of the class driver source should become a valuable resource for driver authors, hardware manufacturers, and open‑source contributors. It offers a baseline implementation that can be studied, improved, and forked for vendor‑specific needs. This is especially important for smaller manufacturers who historically lacked the resources to maintain their own kernel driver stacks.
  • Audio tool and plugin developers have a chance to test and adapt to Arm64 sooner rather than later. Native Arm builds reduce emulation overhead and can unlock better energy efficiency on portable systems when implemented well.
Security and maintainability considerations​
An in‑box kernel driver increases the platform‑wide responsibility to maintain code quality, timely security patches, and robust driver update mechanisms. Microsoft’s plan to ship the driver in‑box implies driver updates will go through Windows servicing channels, which is good for patching speed and distribution, but also means thorough vetting is needed to avoid platform regressions. The open‑source approach helps auditing but does not remove the need for vendor QA, continuous integration, and security reviews.
How realistic is the 2026 retail arrival claim?​
Several outlets have linked the in‑box audio driver timeline to the broader Windows on Arm ecosystem refresh expected with Windows 11 26H1 and next‑generation Arm silicon launches in early 2026. That coupling makes practical sense: OEMs will ship new Arm hardware with updated Windows images and can include the driver as part of the new platform image. However, Microsoft’s own blog post stops short of committing to a 2026 retail ship date; the company promised previews in 2025 and an in‑box deployment when the Arm64 driver meets quality targets. Therefore, 2026 is a plausible retail milestone driven by hardware/OS refresh cycles, but it is not an explicit contractual date from Microsoft — treat 2026 as likely for broad OEM preload, but not strictly guaranteed for every scenario or update channel.
Verdict: meaningful progress, but not an instant fix​
Microsoft’s in‑box low‑latency USB Audio Class 2 driver with a native ASIO interface is a major positive development for the Windows on Arm ecosystem. It addresses a core UX problem — the need for many users to hunt down vendor kernel drivers to get functional ASIO support. The partnership with Qualcomm and Yamaha, the promise of published source code, and early Arm64 drivers from major vendors all point to an industry‑level alignment.
That said, the truly professional audio landscape is complex. Achieving the lowest possible round‑trip latency while preserving battery life, thermal stability, and multi‑client use cases is non‑trivial. Advanced features will still be delivered by dedicated vendor drivers, and plugin/DAW compatibility must be validated on a per‑case basis. The delivery path — previews in 2025, possible wider OEM preload in 2026 — is promising but not a guaranteed hard date for every user.
Final thoughts for Windows on Arm users and pros​
This initiative marks a turning point: Windows on Arm is moving from a niche curiosity for audio professionals toward a first‑class platform for music creation. The in‑box ASIO pathway reduces friction, and the openness of Microsoft’s approach invites vendor collaboration and community feedback.
For audio professionals, the prudent path is to start testing now: work with vendor Arm64 preview drivers where available, evaluate DAW and plugin compatibility, and wait for the Microsoft class driver previews to measure how well it meets your latency and stability needs. The ecosystem is aligning — but real‑world adoption and fine‑grained vendor optimizations will determine when Arm64 becomes the comfortable default for studio and live audio work.
Source: Neowin Microsoft will release a new low-latency audio driver for Windows on Arm in 2026
