WalJohn
Honorable Member
When I go to Settings in the Start window there are no items listed. Where did all the menu items go? Only new thing I have done is set up OneDrive and upload pictures.
If the Settings menu on your Windows computer is not showing any items, it can be frustrating and may indicate an issue with the Windows system configuration. Here are steps you can take to troubleshoot and potentially resolve this problem: 1. Restart Your Computer: - Begin by restarting your computer. This can sometimes resolve minor glitches related to the system's display. 2. Run Windows Update: - Make sure your system is up to date by running Windows Update. Sometimes missing menu options can be due to outdated system files. 3. Run SFC Scan: - Use the System File Checker tool to scan for and repair corrupted or missing system files. Open Command Prompt as an administrator and type sfc /scannow. 4. Check...
If the Settings menu on your Windows computer is not showing any items, it can be frustrating and may indicate an issue with the Windows system configuration. Here are steps you can take to troubleshoot and potentially resolve this problem: 1. Restart Your Computer: - Begin by restarting your computer. This can sometimes resolve minor glitches related to the system's display. 2. Run Windows Update: - Make sure your system is up to date by running Windows Update. Sometimes missing menu options can be due to outdated system files. 3. Run SFC Scan: - Use the System File Checker tool to scan for and repair corrupted or missing system files. Open Command Prompt as an administrator and type sfc /scannow. 4. Check User Account Settings: - Ensure that your user account has the necessary permissions to view and modify settings. Consider creating a new user profile to see if the issue persists there. 5. Disable OneDrive: - Temporarily disable OneDrive to check if it's causing the issue. This can be done by right-clicking the OneDrive icon in the system tray and selecting "Quit OneDrive". 6. Check Group Policy Settings: - Group Policy settings can sometimes affect the visibility of certain system items. Run "gpedit.msc" to access Group Policy Editor and review the settings under Administrative Templates. 7. Create a System Restore Point: - Before making significant changes to system settings, consider creating a restore point so you can revert back if needed. 8. Perform a System Reset: - As a last resort, consider resetting your Windows system. Go to Settings > Update & Security > Recovery and choose the option to reset your PC while keeping your personal files. By following these steps, you should be able to troubleshoot the missing items in the Settings menu and potentially resolve the issue on your Windows computer.
