More BSOD issues
One of several issues im facing is my BSOD issue. I have replaced memory but still getting the bsod. I'm at my witts end, please help.
os:win7 pro (64-bit)
cpu:intel core 2 duo e6300
mem:4gb
I'm also running XP w/ split partition, which is running flawlessly. I've had win7 for awhile now and have yet to get it to run reasonably well.
061710-23462-01.dmp
BugCheck CA, {b, fffffa8002168a20, 1, 0}
Probably caused by : pci.sys
PNP_DETECTED_FATAL_ERROR (ca)
PnP encountered a severe error, either as a result of a problem in a driver or a problem in PnP itself.
MODULE_NAME: pci
FAILURE_BUCKET_ID:  X64_0xCA_B_IMAGE_pci.sys
The PNP_DETECTED_FATAL_ERROR bug check has a value of 0x000000CA. This indicates that the Plug and Play Manager encountered a severe error, probably as a result of a problematic Plug and Play driver. Check your p&p devices.
061910-15974-01.dmp
BugCheck CA, {b, fffffa8001e1c8d0, 1, 0}
MODULE_NAME: pci
082010-20202-01.dmp
BugCheck 7F, {8, 80050033, 6f8, fffff80002a9198e}
Probably caused by : ntkrnlmp.exe ( nt!KiDoubleFaultAbort+b2 )
UNEXPECTED_KERNEL_MODE_TRAP (7f)
This means a trap occurred in kernel mode, and it's a trap of a kind that the kernel isn't allowed to have/catch (bound trap) or that is always instant death (double fault).
MODULE_NAME: nt
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID:  X64_0x7f_8_nt!KiDoubleFaultAbort+b2
support.microsoft.com/kb/842465
This problem occurs if one or more of the processors in the computer:
  • Require a microcode update that is not applied by the computer's basic input/output system (BIOS).
  • Are damaged or defective.
  • Are operating outside their specified ranges for temperature, power, or other conditions.
082010-21278-01.dmp
BugCheck 1000007E, {ffffffffc0000005, fffff80002aa44a1, fffff88002fee0e8, fffff88002fed950}
Probably caused by : memory_corruption ( nt!MiGetNextNode+15 )
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
PROCESS_NAME:  KHALMNPR.exe
DEFAULT_BUCKET_ID:  NULL_CLASS_PTR_DEREFERENCE
MODULE_NAME: nt
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0x7E_nt!MiGetNextNode+15
A hard coded breakpoint or assertion was hit, but this system was booted /NODEBUG.  This is not supposed to happen as developers should never have hardcoded breakpoints in retail code, but ... If this happens, make sure a debugger gets connected, and the system is booted /DEBUG.  This will let us see why this breakpoint is happening.
khalmnpr.exe - Logitech Mouse Utility, a process installed alongside Logitech mice which allows for advanced configuration and diagnostics of their range of multimedia products. This program is a non-essential process, but should not be terminated unless suspected to be causing problems.
Run memtest86 overnight. If turns out memory related, run your system with 1 stick of ram, then replace it with the other sticks you have, until you identify which one causes the problem.
082310-21949-01.dmp
BugCheck 24, {1904fb, fffff88006dec538, fffff88006debda0, fffff80002adbc9c}
Probably caused by : Ntfs.sys ( Ntfs!NtfsAcquireFcbWithPaging+13b )
NTFS_FILE_SYSTEM (24)
MODULE_NAME: Ntfs
FAILURE_BUCKET_ID:  X64_0x24_Ntfs!NtfsAcquireFcbWithPaging+13b
NTFS_FILE_SYSTEM (24) <- triggered by the Ntfs.sys file which is a driver that enables a PC to read and write a hard drive formatted with the NTFS file system. How to solve it:
- from the os or from the startup repair (with 7 dvd in drive) -> command line, type chkdsk /r and wait for the operation to complete.
Your drivers are up to date enough, but you may want to update the following if newer versions are available:
ax88772.sys Wed Jun 10 05:18:09 2009
ASIX AX88772/AX88772A Network Driver - USB2.0 Fast Ethernet Adapter - ASIX Electronics Corp.
Pay some attention to these:
atikmdag.sys Fri Apr 24 13:51:57 2009
ATI Radeon Kernel Mode driver - update if you actually have an ATI card.
dump_nvstor.sys Wed May 20 09:45:37 2009
NVIDIA® nForce(TM) Sata Performance Driver - NVIDIA nForce(TM) SATA Driver - NVIDIA Corporation - update if you actually have NVIDIA hardware and if newer versions for these are available. Otherwise you shouldn't store them in your system.
Update your Creative drivers.
Uninstall AVG in safe mode using this tool found here, then install MSE in normal mode:
AV Uninstallers - Windows 7 Forums
Follow Cybercore's post too.
When done with everything, if crashes persist, then please post a new dump so we can take it from there.
