Windows 7 mov to avi/mp4 converter
franktheman7
Well-Known Member
I just can't find a program to convert a mov to avi and or mp4
if someone knows of a really good program that will do this in good quality
I would be very greatful, I looked all over the place with no luck :(
Thank you all so muck,
Frank
The best way to convert MOV files to MP4 is by the help of MP4 converter software. This powerful and easy to use converter provides us with advanced features so that we can enhance and optimize the quality of the videos. As MP4 is the most useable format and can be used by any of the devices. So anytime it can be used for converting.
  • It Can edit video files
  • Let you customize the output settings
  • It is convenient and Easy to use
For free and secure MP4 to MOV converter use Link Removed
As far as I can see from the link provided this software is NOT FREE.
Pat Cooke
I use Freemake and Freemedia converter extensively and am very happy.
bob
Ihave Avs4You, afew of them and they work great but now for .mov files
but I found one the works great called PCHand Media Converter Pro
Thank yoy,
Franktheman7
Pat Cooke
bob
  • Like
Reactions: whs
