bluenite
After some last Windows10 update the MSEdge was set as the default PDF files viewer. When I switch it back to Acrobat, it returns again as before. I tried it more times using the right mouse with checked option, in settings/default apps by file type, nothing helps. No option to see the Edge setting. Can it be set somehow?
OR – how to get rid completely that loutish sw? Normal way doesn’t work…
Thanks for any advice
Peter
livix07
Honorable Member
It could be done by editing the registry but I DON'T RECOMMEND THAT.
Is Windows up to date on your computer?
It seems to me that Windows is corrupted on your computer.
