Windows 7 Multiple BSOD's over the past weeks (no hair left on my head)
lh77
This new system has been experiencing multiple BSOD's since it's creation for the past two weeks. I've run driver verifier, updated removed and then re-installed all programs and drivers but have been unable to narrow down the cause. Any help would be greatly, greatly appreciated...
the sf_diag info has been attached
thanks in advance
  • SF_15-04-2013.zip
usasma
Fantastic Member
Only 82 Windows Updates installed. Most systems have 150 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
You have 6 hard drives. What is the make/model/wattage and age of your Power Supply?
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website). Be sure to update ALL controllers on the motherboard! I STRONGLY suggest not using controller drivers older than mid-2012 with SSD's.
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
05 Jan 2013 - very interesting post about difficulties with the Marvell controllers even when not connected to the SSD drives: Solved Win8 x64 PC reboots when waking from sleep
27 Feb 2013 - I'm starting to see much better reliability with SSD's using current (mid-2012 and later) storage drivers. I have withdrawn my objections to using these devices in everyday systems.
If you're overclocking, please stop the overclock while we're troubleshooting. Feel free to resume the overclock once the system has been stabilized.
Long ago I learned that the first troubleshooting step in an overclocked system is to remove the overclock. This is for 2 reasons:
1) in case the overclock is at fault (and it hasn't damaged any hardware yet) - this will fix the problem.
2) the tests we use for troubleshooting are based on a standard system operating normally - so an overclocked system won't necessarily give correct results because of the stress on the components. This is why I recommend stopping the overclock completely while troubleshooting.
Also, I found that overclocks will degrade over time - the system just won't be able to hold a high overclock forever. The system will get older and it's tolerance for this sort of stress will lessen - resulting in more errors.
Finally, hardware errors aren't necessarily just hardware, they can be:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS problems (check for updates at the motherboard manufacturer's website)
- overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Mon Apr 15 16:07:42.256 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041513-16551-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:[B]0 days 3:50:55.100[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KeInterlockedClearProcessorAffinityEx+36 )[/B]
BugCheck [B]A, {d0, 2, 0, fffff800034d98d6}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000000A]IRQL_NOT_LESS_OR_EQUAL (a)[/url]
Arguments:
Arg1: 00000000000000d0, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff800034d98d6, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME:  plugin-contain
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KeInterlockedClearProcessorAffinityEx+36[/B]
CPUID:        "Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz"
MaxSpeed:     3600
CurrentSpeed: [B]4549[/B]
Processor may be overclocked!
Expected Frequency:   3600
Actual Frequency:     4549
Overclock Ratio:      [color=red]1.26361[/color]
  BIOS Version                  3501
  BIOS Release Date             03/14/2013
**************************Mon Apr 15 12:09:47.387 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041513-10420-01.dmp]
System Uptime:[B]0 days 0:01:14.230[/B]
Probably caused by :[B]Unknown_Image ( ANALYSIS_INCONCLUSIVE )[/B]
BugCheck [B]101, {19, 0, fffff88003142180, 2}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000101]CLOCK_WATCHDOG_TIMEOUT (101)[/url]
Arguments:
Arg1: 0000000000000019, Clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0.
Arg3: fffff88003142180, The PRCB address of the hung processor.
Arg4: 0000000000000002, 0.
BUGCHECK_STR:  CLOCK_WATCHDOG_TIMEOUT_8_PROC
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]X64_CLOCK_WATCHDOG_TIMEOUT_8_PROC_ANALYSIS_INCONCLUSIVE[/B]
MaxSpeed:     3600
  BIOS Version                  3501
**************************Sun Apr 14 13:57:53.721 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041413-9937-01.dmp]
System Uptime:[B]0 days 0:11:00.424[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiKernelCalloutExceptionHandler+e )[/B]
BugCheck [B]1E, {0, 0, 0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000001E]KMODE_EXCEPTION_NOT_HANDLED (1e)[/url]
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
BUGCHECK_STR:  0x1E
FAILURE_BUCKET_ID: [B]X64_0x1E_nt!KiKernelCalloutExceptionHandler+e[/B]
MaxSpeed:     3600
  BIOS Version                  3501
**************************Fri Apr 12 14:30:14.928 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041213-10998-01.dmp]
System Uptime:[B]0 days 0:58:13.772[/B]
Arguments:
PROCESS_NAME:  svchost.exe
MaxSpeed:     3600
  BIOS Version                  3501
**************************Fri Apr 12 11:34:50.645 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041213-11013-01.dmp]
System Uptime:[B]0 days 0:00:25.488[/B]
BugCheck [B]101, {19, 0, fffff880032a5180, 5}[/B]
Arguments:
Arg3: fffff880032a5180, The PRCB address of the hung processor.
Arg4: 0000000000000005, 0.
PROCESS_NAME:  updaterstartup
MaxSpeed:     3600
  BIOS Version                  3501
**************************Fri Apr 12 10:56:20.783 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041213-11044-01.dmp]
System Uptime:[B]0 days 0:15:48.626[/B]
BugCheck [B]101, {19, 0, fffff880031e6180, 4}[/B]
Arguments:
Arg3: fffff880031e6180, The PRCB address of the hung processor.
Arg4: 0000000000000004, 0.
PROCESS_NAME:  mbamservice.ex
FAILURE_BUCKET_ID: [B]X64_CLOCK_WATCHDOG_TIMEOUT_8_PROC_VRF_ANALYSIS_INCONCLUSIVE[/B]
**************************Wed Apr 10 08:57:26.371 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041013-11419-01.dmp]
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]0 days 0:00:22.980[/B]
Probably caused by :[B]Pool_Corruption ( nt!ExDeferredFreePool+192 )[/B]
BugCheck [B]C5, {fffff81002a176b0, 2, 0, fffff800029bca4e}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000C5]DRIVER_CORRUPTED_EXPOOL (c5)[/url]
Arguments:
Arg1: fffff81002a176b0, memory referenced
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff800029bca4e, address which referenced memory
BUGCHECK_STR:  0xC5_2
FAILURE_BUCKET_ID: [B]X64_0xC5_2_nt!ExDeferredFreePool+192[/B]
MaxSpeed:     3600
  BIOS Version                  3501
**************************Wed Apr 10 08:54:14.257 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041013-11341-01.dmp]
System Uptime:[B]0 days 0:00:25.882[/B]
BugCheck [B]C5, {fffff81002a0e6b0, 2, 0, fffff800029b3a4e}[/B]
Arguments:
Arg1: fffff81002a0e6b0, memory referenced
Arg4: fffff800029b3a4e, address which referenced memory
MaxSpeed:     3600
  BIOS Version                  3501
**************************Wed Apr 10 08:48:40.180 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041013-10810-01.dmp]
System Uptime:[B]0 days 0:00:24.680[/B]
BugCheck [B]C5, {fffff81002a516b0, 2, 0, fffff800029f6a4e}[/B]
Arguments:
Arg1: fffff81002a516b0, memory referenced
Arg4: fffff800029f6a4e, address which referenced memory
MaxSpeed:     3600
  BIOS Version                  3501
**************************Wed Apr 10 08:34:34.073 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041013-11325-01.dmp]
System Uptime:[B]0 days 0:00:23.588[/B]
BugCheck [B]C5, {fffff81002a136b0, 2, 0, fffff800029b8a4e}[/B]
Arguments:
Arg1: fffff81002a136b0, memory referenced
Arg4: fffff800029b8a4e, address which referenced memory
MaxSpeed:     3600
  BIOS Version                  3501
**************************Wed Apr 10 08:32:58.834 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041013-11232-01.dmp]
System Uptime:[B]0 days 0:00:36.458[/B]
BugCheck [B]C5, {fffff81002a6a6b0, 2, 0, fffff80002a0fa4e}[/B]
Arguments:
Arg1: fffff81002a6a6b0, memory referenced
Arg4: fffff80002a0fa4e, address which referenced memory
MaxSpeed:     3600
  BIOS Version                  3501
**************************Wed Apr 10 08:30:46.700 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041013-11310-01.dmp]
System Uptime:[B]0 days 15:24:52.200[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ExFreePoolWithTag+212 )[/B]
BugCheck [B]50, {fffff8e0022729bc, 1, fffff800029fe2f2, 5}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000050]PAGE_FAULT_IN_NONPAGED_AREA (50)[/url]
Arguments:
Arg1: fffff8e0022729bc, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff800029fe2f2, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000005, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME:  explorer.exe
FAILURE_BUCKET_ID: [B]X64_0x50_nt!ExFreePoolWithTag+212[/B]
MaxSpeed:     3600
  BIOS Version                  3501
**************************Tue Apr  9 17:05:01.935 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040913-11310-01.dmp]
System Uptime:[B]0 days 0:00:41.433[/B]
*** WARNING: Unable to verify timestamp for e1c62x64.sys
*** ERROR: Module load completed but symbols could not be loaded for e1c62x64.sys
Probably caused by :[B]e1c62x64.sys ( e1c62x64+1fb23 )[/B]
BugCheck [B]19, {20, fffffa8010275130, fffffa8010275250, 4120013}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000019]BAD_POOL_HEADER (19)[/url]
Arguments:
Arg1: 0000000000000020, a pool block header size is corrupt.
Arg2: fffffa8010275130, The pool entry we were looking for within the page.
Arg3: fffffa8010275250, The next pool entry.
Arg4: 0000000004120013, (reserved)
BUGCHECK_STR:  0x19_20
FAILURE_BUCKET_ID: [B]X64_0x19_20_e1c62x64+1fb23[/B]
MaxSpeed:     3600
  BIOS Version                  3501
**************************Tue Apr  9 17:03:28.411 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040913-11122-01.dmp]
System Uptime:[B]0 days 0:01:05.911[/B]
BugCheck [B]C5, {fffff81002a146b0, 2, 0, fffff800029b9a4e}[/B]
Arguments:
Arg1: fffff81002a146b0, memory referenced
Arg4: fffff800029b9a4e, address which referenced memory
MaxSpeed:     3600
  BIOS Version                  3501
**************************Tue Apr  9 17:01:31.696 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040913-11200-01.dmp]
System Uptime:[B]0 days 0:02:22.306[/B]
BugCheck [B]19, {20, fffffa800fb18d70, fffffa800fb18e90, 4120015}[/B]
Arguments:
Arg2: fffffa800fb18d70, The pool entry we were looking for within the page.
Arg3: fffffa800fb18e90, The next pool entry.
Arg4: 0000000004120015, (reserved)
MaxSpeed:     3600
  BIOS Version                  3501
**************************Tue Apr  9 15:01:07.672 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040913-11169-01.dmp]
System Uptime:[B]0 days 0:01:09.061[/B]
BugCheck [B]C5, {fffff81002a226b0, 2, 0, fffff800029c7a4e}[/B]
Arguments:
Arg1: fffff81002a226b0, memory referenced
Arg4: fffff800029c7a4e, address which referenced memory
MaxSpeed:     3600
  BIOS Version                  3501
**************************Tue Apr  9 14:59:03.804 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040913-11154-01.dmp]
System Uptime:[B]0 days 0:08:55.648[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!DebugPrompt+18 )[/B]
BugCheck [B]3B, {80000003, fffff800034c3ab8, fffff88008fd5920, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 0000000080000003, Exception code that caused the bugcheck
Arg2: fffff800034c3ab8, Address of the instruction which caused the bugcheck
Arg3: fffff88008fd5920, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
DEFAULT_BUCKET_ID: [B][COLOR=RED]VERIFIER_ENABLED_VISTA_MINIDUMP[/COLOR][/B]
PROCESS_NAME:  WRSA.exe
FAILURE_BUCKET_ID: [B]X64_0x3B_VRF_nt!DebugPrompt+18[/B]
MaxSpeed:     3600
  BIOS Version                  3501
**************************Tue Apr  9 12:53:15.043 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040913-20326-01.dmp]
System Uptime:[B]0 days 3:31:07.887[/B]
*** WARNING: Unable to verify timestamp for snapman.sys
*** ERROR: Module load completed but symbols could not be loaded for snapman.sys
Probably caused by :[B]snapman.sys ( snapman+7f86 )[/B]
BugCheck [B]C4, {f6, c, fffffa8010777290, fffff88001b8cf86}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000C4]DRIVER_VERIFIER_DETECTED_VIOLATION (c4)[/url]
Arguments:
Arg1: 00000000000000f6, Referencing user handle as KernelMode.
Arg2: 000000000000000c, Handle value being referenced.
Arg3: fffffa8010777290, Address of the current process.
Arg4: fffff88001b8cf86, Address inside the driver that is performing the incorrect reference.
BUGCHECK_STR:  0xc4_f6
FAILURE_BUCKET_ID: [B]X64_0xc4_f6_VRF_snapman+7f86[/B]
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 20:00:43.513 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-19858-01.dmp]
System Uptime:[B]0 days 1:59:03.245[/B]
BugCheck [B]C4, {f6, c, fffffa8010995b30, fffff88001b58f86}[/B]
Arguments:
Arg3: fffffa8010995b30, Address of the current process.
Arg4: fffff88001b58f86, Address inside the driver that is performing the incorrect reference.
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 17:23:13.906 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-12542-01.dmp]
System Uptime:[B]0 days 0:00:20.749[/B]
BugCheck [B]3B, {80000003, fffff800034c9ab8, fffff880028aa570, 0}[/B]
Arguments:
Arg2: fffff800034c9ab8, Address of the instruction which caused the bugcheck
Arg3: fffff880028aa570, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
PROCESS_NAME:  csrss.exe
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 17:18:36.890 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-12511-01.dmp]
System Uptime:[B]0 days 0:00:20.734[/B]
BugCheck [B]3B, {80000003, fffff8000347bab8, fffff880027b9450, 0}[/B]
Arguments:
Arg2: fffff8000347bab8, Address of the instruction which caused the bugcheck
Arg3: fffff880027b9450, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 17:10:18.015 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-12636-02.dmp]
System Uptime:[B]0 days 0:00:20.858[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!RtlDispatchException+122 )[/B]
BugCheck [B]A, {fffff8000379cf36, 2, 0, fffff800034e8332}[/B]
Arguments:
Arg1: fffff8000379cf36, memory referenced
Arg4: fffff800034e8332, address which referenced memory
BUGCHECK_STR:  0xA
FAILURE_BUCKET_ID: [B]X64_0xA_VRF_nt!RtlDispatchException+122[/B]
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 17:05:41.937 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-12636-01.dmp]
System Uptime:[B]0 days 0:00:20.670[/B]
BugCheck [B]3B, {80000003, fffff80003471ab8, fffff880025fa480, 0}[/B]
Arguments:
Arg2: fffff80003471ab8, Address of the instruction which caused the bugcheck
Arg3: fffff880025fa480, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 17:02:49.844 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-12589-01.dmp]
System Uptime:[B]0 days 0:00:20.687[/B]
BugCheck [B]3B, {80000003, fffff80003478ab8, fffff8800278c450, 0}[/B]
Arguments:
Arg2: fffff80003478ab8, Address of the instruction which caused the bugcheck
Arg3: fffff8800278c450, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 16:51:06.405 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-12620-01.dmp]
System Uptime:[B]0 days 0:00:21.138[/B]
BugCheck [B]3B, {80000003, fffff8000346dab8, fffff8800261f920, 0}[/B]
Arguments:
Arg2: fffff8000346dab8, Address of the instruction which caused the bugcheck
Arg3: fffff8800261f920, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 16:30:29.296 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-13431-02.dmp]
System Uptime:[B]0 days 0:00:21.139[/B]
BugCheck [B]3B, {80000003, fffff800034ceab8, fffff88002842920, 0}[/B]
Arguments:
Arg2: fffff800034ceab8, Address of the instruction which caused the bugcheck
Arg3: fffff88002842920, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 15:54:57.767 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-12183-01.dmp]
System Uptime:[B]0 days 0:00:21.610[/B]
BugCheck [B]A, {fffff8000376cf36, 2, 0, fffff800034b8332}[/B]
Arguments:
Arg1: fffff8000376cf36, memory referenced
Arg4: fffff800034b8332, address which referenced memory
BUGCHECK_STR:  0xA
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 15:45:04.265 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-19921-01.dmp]
System Uptime:[B]0 days 0:00:20.997[/B]
BugCheck [B]3B, {80000003, fffff800034bdab8, fffff880025ef450, 0}[/B]
Arguments:
Arg2: fffff800034bdab8, Address of the instruction which caused the bugcheck
Arg3: fffff880025ef450, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
MaxSpeed:     3600
  BIOS Version                  3501
**************************Mon Apr  8 15:38:35.312 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040813-13416-01.dmp]
System Uptime:[B]0 days 0:00:21.155[/B]
BugCheck [B]A, {fffff80003761f36, 2, 0, fffff800034ad332}[/B]
Arguments:
Arg1: fffff80003761f36, memory referenced
Arg4: fffff800034ad332, address which referenced memory
BUGCHECK_STR:  0xA
MaxSpeed:     3600
  BIOS Version                  3501
**************************Fri Apr  5 19:05:12.778 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040513-20248-01.dmp]
System Uptime:[B]0 days 0:10:57.621[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!PoIdle+4f )[/B]
BugCheck [B]50, {fffffa800cdedb44, 0, fffff800034da31f, 2}[/B]
Arguments:
Arg1: fffffa800cdedb44, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff800034da31f, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
BUGCHECK_STR:  0x50
FAILURE_BUCKET_ID: [B]X64_0x50_nt!PoIdle+4f[/B]
MaxSpeed:     3600
  BIOS Version                  3501
**************************Fri Apr  5 08:54:54.364 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040513-20139-01.dmp]
System Uptime:[B]0 days 0:04:22.207[/B]
BugCheck [B]101, {19, 0, fffff880033e6180, 4}[/B]
Arguments:
Arg3: fffff880033e6180, The PRCB address of the hung processor.
PROCESS_NAME:  dllhost.exe
MaxSpeed:     3600
  BIOS Version                  3305
  BIOS Release Date             12/25/2012
**************************Thu Apr  4 11:47:47.593 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040413-17799-01.dmp]
System Uptime:[B]0 days 2:14:46.436[/B]
BugCheck [B]101, {19, 0, fffff88003342180, 2}[/B]
Arguments:
Arg3: fffff88003342180, The PRCB address of the hung processor.
MaxSpeed:     3600
  BIOS Version                  3305
[/font]
3rd Party Drivers:
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
btath_rcp.sys               Thu Jun 24 02:17:21 2010 (4C22F871)
btath_flt.sys               Thu Jun 24 02:17:38 2010 (4C22F882)
btath_bus.sys               Thu Jun 24 02:17:43 2010 (4C22F887)
btath_hcrp.sys              Tue Jun 29 05:30:43 2010 (4C29BD43)
ICCWDT.sys                  Wed Aug 18 04:27:45 2010 (4C6B9981)
btath_lwflt.sys             Mon Sep 13 04:26:54 2010 (4C8DE04E)
btath_a2dp.sys              Mon Feb 14 20:47:47 2011 (4D59DB43)
btfilter.sys                Tue Mar  8 01:15:22 2011 (4D75C97A)
ASUSwh.sys                  Thu Sep 15 12:24:13 2011 (4E7226AD)
ASUScr.sys                  Thu Sep 15 12:24:17 2011 (4E7226B1)
ASUSumsc.sys                Thu Sep 15 12:24:24 2011 (4E7226B8)
ASUSstpt.sys                Thu Sep 15 12:24:31 2011 (4E7226BF)
mvxxmm.sys                  Mon Sep 19 07:31:37 2011 (4E772819)
mvs91xx.sys                 Mon Sep 19 07:31:51 2011 (4E772827)
mv91cons.sys                Mon Sep 19 07:36:08 2011 (4E772928)
ASUSFILTER.sys              Tue Sep 20 11:46:33 2011 (4E78B559)
asmtxhci.sys                Wed Nov  2 23:00:22 2011 (4EB203C6)
asmthub3.sys                Wed Nov  2 23:00:32 2011 (4EB203D0)
e1c62x64.sys                Thu Mar 15 23:57:28 2012 (4F62BA28)
HECIx64.sys                 Thu Jul 12 22:18:26 2012 (4FFF8572)
AsIO.sys                    Wed Aug 22 05:54:47 2012 (5034AC67)
nvhda64v.sys                Wed Dec 19 00:41:41 2012 (50D15395)
tib_mounter.sys             Thu Dec 27 08:25:05 2012 (50DC4C31)
snapman.sys                 Wed Jan 16 08:44:06 2013 (50F6AEA6)
vididr.sys                  Thu Feb 14 01:47:31 2013 (511C8883)
vidsflt.sys                 Thu Feb 14 02:04:41 2013 (511C8C89)
fltsrv.sys                  Fri Mar  1 08:53:39 2013 (5130B2E3)
nvlddmkm.sys                Thu Mar 14 21:37:00 2013 (51427B3C)
tib.sys                     Wed Mar 20 05:00:38 2013 (51497AB6)
mbam.sys                    Thu Feb 28 15:33:07 2013 (512FBF03)
WRkrn.sys                   Wed Mar 27 16:00:33 2013 (51534FE1)
nvhda64v.sys                Tue May 10 05:41:18 2011 (4DC9083E)
afcdp.sys                   Wed Jul 20 10:46:03 2011 (4E26EA2B)
nvBridge.kmd                Fri May 20 23:58:23 2011 (4DD7385F)
nvlddmkm.sys                Tue Oct  2 14:21:13 2012 (506B3099)
tib_mounter.sys             Thu Jul 12 07:27:34 2012 (4FFEB4A6)
vididr.sys                  Fri Jul 27 09:39:44 2012 (50129A20)
vidsflt.sys                 Fri Jul 27 09:51:02 2012 (50129CC6)
fltsrv.sys                  Mon Jul 30 04:45:25 2012 (501649A5)
snapman.sys                 Fri Aug 10 05:14:04 2012 (5024D0DC)
[/font]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=btath_rcp.sys
http://www.carrona.org/drivers/driver.php?id=btath_flt.sys
http://www.carrona.org/drivers/driver.php?id=btath_bus.sys
http://www.carrona.org/drivers/driver.php?id=btath_hcrp.sys
http://www.carrona.org/drivers/driver.php?id=ICCWDT.sys
http://www.carrona.org/drivers/driver.php?id=btath_lwflt.sys
http://www.carrona.org/drivers/driver.php?id=btath_a2dp.sys
http://www.carrona.org/drivers/driver.php?id=btfilter.sys
http://www.carrona.org/drivers/driver.php?id=ASUSwh.sys
http://www.carrona.org/drivers/driver.php?id=ASUScr.sys
http://www.carrona.org/drivers/driver.php?id=ASUSumsc.sys
http://www.carrona.org/drivers/driver.php?id=ASUSstpt.sys
http://www.carrona.org/drivers/driver.php?id=mvxxmm.sys
http://www.carrona.org/drivers/driver.php?id=mvs91xx.sys
http://www.carrona.org/drivers/driver.php?id=mv91cons.sys
http://www.carrona.org/drivers/driver.php?id=ASUSFILTER.sys
http://www.carrona.org/drivers/driver.php?id=asmtxhci.sys
http://www.carrona.org/drivers/driver.php?id=asmthub3.sys
http://www.carrona.org/drivers/driver.php?id=e1c62x64.sys
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
http://www.carrona.org/drivers/driver.php?id=AsIO.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=tib_mounter.sys
http://www.carrona.org/drivers/driver.php?id=snapman.sys
http://www.carrona.org/drivers/driver.php?id=vididr.sys
http://www.carrona.org/drivers/driver.php?id=vidsflt.sys
http://www.carrona.org/drivers/driver.php?id=fltsrv.sys
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
tib.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=mbam.sys
http://www.carrona.org/drivers/driver.php?id=WRkrn.sys
http://www.carrona.org/drivers/driver.php?id=afcdp.sys
http://www.carrona.org/drivers/driver.php?id=nvBridge.kmd
lh77
Thanks for your excellent input.
After updating all the drivers the source of my remaining BSOD issue was the overclocked cpu.
I now have a rock solid stable 64bit win 7 platform with the following characteristics.
ASUS P9X79 Pro mobo 16gb ram, Intel i&-3820 cpu at 3.60 Ghz. 750 w power supply.
My overclocking to 4.60 GHZ as pointed out was the last remaining cause of instability.
All win 7 programs files are on a Samsung SSD 840 drive using the latest driver on a 6Gb Intel SATA controller.
Other non OS programs are on another 2TB drive cached with another 60Gb SSD, these two drives use the
Marvell 91xx SATA 6G controller.
I use the ASUS Ai Suite II for all mobo features. Although I've read various negative comments about SSD drives,
the Marvell 91xx controller and the AI Suite II, all of these various components are now rock solid.
FYI - the Marvell Drivers were download from ASUS and not another source.
My BSOD issues were quite frustrating and my experience with Driver Verifier was not pleasant. It seemed to make troubleshooting more difficult not
less by pointing fingers at almost every driver installed.
Again thanks for this excellent resource, it emerged as the turning point in resolving my BSOD issues.
usasma
Fantastic Member
The key to troubleshooting hardware issues is, first, a "pattern" that is no pattern. That is, random errors blaming everything under the sun. And especially when using Driver Verifier to only verify 3rd party drivers.
Once you see that "pattern", then you have to rule out other "low-level" causes, such as:
- BIOS issues (check for updates at the motherboard manufacturer's website)
If you rule the above stuff out - then you can be pretty sure that it's a hardware problem (which includes overclocking). In the case of overclocking, the ultimate test is to remove the overclock and see if the system works without problem.
Just for the sake of completeness, the last thing we consider is Windows problems as they are the least likey to occur.
Top Bottom
