My Acer notebook crashed manytimes with BSOD please help.
Recently it was OK. But after windows fail to restart. I restored by using norton ghost. After booting windows, BSOD happen about 4 times (as attached). I don't know what went wrong. But after booting in safe mode, it work fine. I tried to update driver in safe mode, all said updated.
zigzag3143
Honorable Member
Microsoft MVP
Four different causes in 4 crashes. There are several possibilities.
1-Old drivers
NTIDrvr.sys    3/24/2009 11:09:39 PM        fffff880`05293000    fffff880`0529b000    0x00008000    0x49c9a073
UBHelper.sys    4/27/2009 4:48:19 AM        fffff880`0528b000    fffff880`05293000    0x00008000    0x49f57153
mwlPSDFilter.sys    6/2/2009 6:07:30 AM        fffff880`042b3000    fffff880`042bc000    0x00009000    0x4a24f9e2
mwlPSDNServ.sys    6/2/2009 6:07:39 AM        fffff880`02e70000    fffff880`02e78000    0x00008000    0x4a24f9eb
mwlPSDVDisk.sys    6/2/2009 6:15:29 AM        fffff880`02e5d000    fffff880`02e70000    0x00013000    0x4a24fbc1
How To Find Drivers:
- search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- - The most common drivers are listed on this page: Driver Reference Driver Reference
- - Driver manufacturer links are on this page: Drivers and Downloads
2- Macaffee. I would remove and replace with Microsoft Security Essentials
How to uninstall or reinstall supported McAfee consumer products using the McAfee Consumer Products Removal tool (MCPR.exe)
Virus, Spyware & Malware Protection | Microsoft Security Essentials
3-Since all 4 point towards memory exceptions I would also run memtest
Download a copy of Memtest86 and burn the ISO to a CD using Iso Recorder or another ISO burning program.
Boot from the CD, and leave it running for at least 5 or 6 passes.
Just remember, any time Memtest reports errors, it can be either bad RAM or a bad motherboard slot.
Test the sticks individually, and if you find a good one, test it in all slots.
Great advice! I follow step by step. And now problem is gone. My notebook works well now. Thank you very much.
zigzag3143
Honorable Member
Microsoft MVP
My pleasure, glad you are working again. Ken
