Hinotora
Hi, Im not so sure is win 8 right for my pc? If im looking for specs, then it shold be ok. I have atm win8 in my pc for a week now, after the install my pc worked good, but now its so slow, and in taskmanager i see that service host and some kind of update thing uses all my ram. Or what kind of op i shold use to get good preformance.
Windows 8 Pro 64-bit (6.2, Build 9200)
BIOS: BIOS Date: 09/13/07 11:13:56 Ver: 08.00.12
AMD Athlon(tm) Processor LE-1620, ~2.4GHz (2400MHz)
2560MB RAM
1792MB used, 2896MB available
DirectXŖ©»: DirectX 11
NVIDIA GeForce 8500 GT
Integrated RAMDAC
1263 MB
Please post a picture of the Resource Monitor > Memory tab - like the example below. That will give us more clues.
Shouldn't be an issue. I run it on less.
AMD 64 3400+ 2.2ghz
2gb ram
hd4670 1gb (but have run it on integrated nvidia 6150)
Like whs said, post your resource monitor/memory
