Windows 11 mysql not starting
brijeshh
2022-12-17 12:13:59 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2022-12-17 12:13:59 0 [Note] InnoDB: Uses event mutexes
2022-12-17 12:13:59 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2022-12-17 12:13:59 0 [Note] InnoDB: Number of pools: 1
2022-12-17 12:13:59 0 [Note] InnoDB: Using SSE2 crc32 instructions
2022-12-17 12:13:59 0 [Note] InnoDB: Initializing buffer pool, total size = 16M, instances = 1, chunk size = 16M
2022-12-17 12:13:59 0 [Note] InnoDB: Completed initialization of buffer pool
2022-12-17 12:13:59 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=300288
2022-12-17 12:13:59 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2022-12-17 12:13:59 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2022-12-17 12:13:59 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2022-12-17 12:13:59 0 [Note] InnoDB: Setting file 'C:\xampp\mysql\data\ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2022-12-17 12:13:59 0 [Note] InnoDB: File 'C:\xampp\mysql\data\ibtmp1' size is now 12 MB.
2022-12-17 12:13:59 0 [Note] InnoDB: Waiting for purge to start
2022-12-17 12:14:00 0 [Note] InnoDB: 10.4.27 started; log sequence number 300297; transaction id 170
2022-12-17 12:14:00 0 [Note] InnoDB: Loading buffer pool(s) from C:\xampp\mysql\data\ib_buffer_pool
2022-12-17 12:14:00 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-12-17 12:14:00 0 [Note] Server socket created on IP: '::'.
2022-12-19 12:16:51 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2022-12-19 12:16:51 0 [Note] InnoDB: Uses event mutexes
2022-12-19 12:16:51 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2022-12-19 12:16:51 0 [Note] InnoDB: Number of pools: 1
2022-12-19 12:16:51 0 [Note] InnoDB: Using SSE2 crc32 instructions
2022-12-19 12:16:51 0 [Note] InnoDB: Initializing buffer pool, total size = 16M, instances = 1, chunk size = 16M
2022-12-19 12:16:51 0 [Note] InnoDB: Completed initialization of buffer pool
2022-12-19 12:16:51 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=305845
2022-12-19 12:16:51 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2022-12-19 12:16:51 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2022-12-19 12:16:51 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2022-12-19 12:16:51 0 [Note] InnoDB: Setting file 'C:\xampp\mysql\data\ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2022-12-19 12:16:51 0 [Note] InnoDB: File 'C:\xampp\mysql\data\ibtmp1' size is now 12 MB.
2022-12-19 12:16:51 0 [Note] InnoDB: Waiting for purge to start
2022-12-19 12:16:51 0 [Note] InnoDB: 10.4.27 started; log sequence number 305854; transaction id 208
2022-12-19 12:16:51 0 [Note] InnoDB: Loading buffer pool(s) from C:\xampp\mysql\data\ib_buffer_pool
2022-12-19 12:16:51 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-12-19 12:16:51 0 [Note] InnoDB: Buffer pool(s) load completed at 221219 12:16:51
2022-12-19 12:16:51 0 [Note] Server socket created on IP: '::'.
2022-12-20 12:58:15 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2022-12-20 12:58:15 0 [Note] InnoDB: Uses event mutexes
2022-12-20 12:58:15 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2022-12-20 12:58:15 0 [Note] InnoDB: Number of pools: 1
2022-12-20 12:58:15 0 [Note] InnoDB: Using SSE2 crc32 instructions
2022-12-20 12:58:15 0 [Note] InnoDB: Initializing buffer pool, total size = 16M, instances = 1, chunk size = 16M
2022-12-20 12:58:15 0 [Note] InnoDB: Completed initialization of buffer pool
2022-12-20 12:58:15 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=313073
2022-12-20 12:58:15 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2022-12-20 12:58:15 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2022-12-20 12:58:15 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2022-12-20 12:58:15 0 [Note] InnoDB: Setting file 'C:\xampp\mysql\data\ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2022-12-20 12:58:15 0 [Note] InnoDB: File 'C:\xampp\mysql\data\ibtmp1' size is now 12 MB.
2022-12-20 12:58:15 0 [Note] InnoDB: Waiting for purge to start
2022-12-20 12:58:15 0 [Note] InnoDB: 10.4.27 started; log sequence number 313082; transaction id 235
2022-12-20 12:58:15 0 [Note] InnoDB: Loading buffer pool(s) from C:\xampp\mysql\data\ib_buffer_pool
2022-12-20 12:58:15 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-12-20 12:58:15 0 [Note] InnoDB: Buffer pool(s) load completed at 221220 12:58:15
2022-12-20 12:58:15 0 [Note] Server socket created on IP: '::'.
2022-12-20 12:58:20 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2022-12-20 12:58:20 0 [Note] InnoDB: Uses event mutexes
2022-12-20 12:58:20 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2022-12-20 12:58:20 0 [Note] InnoDB: Number of pools: 1
2022-12-20 12:58:20 0 [Note] InnoDB: Using SSE2 crc32 instructions
2022-12-20 12:58:20 0 [Note] InnoDB: Initializing buffer pool, total size = 16M, instances = 1, chunk size = 16M
2022-12-20 12:58:20 0 [Note] InnoDB: Completed initialization of buffer pool
2022-12-20 12:58:20 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=313073
2022-12-20 12:58:20 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2022-12-20 12:58:20 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2022-12-20 12:58:20 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2022-12-20 12:58:20 0 [Note] InnoDB: Setting file 'C:\xampp\mysql\data\ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2022-12-20 12:58:20 0 [Note] InnoDB: File 'C:\xampp\mysql\data\ibtmp1' size is now 12 MB.
2022-12-20 12:58:20 0 [Note] InnoDB: Waiting for purge to start
2022-12-20 12:58:20 0 [Note] InnoDB: 10.4.27 started; log sequence number 313082; transaction id 235
2022-12-20 12:58:20 0 [Note] InnoDB: Loading buffer pool(s) from C:\xampp\mysql\data\ib_buffer_pool
2022-12-20 12:58:20 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-12-20 12:58:20 0 [Note] Server socket created on IP: '::'.
2022-12-22 11:25:47 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2022-12-22 11:25:47 0 [Note] InnoDB: Uses event mutexes
2022-12-22 11:25:47 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2022-12-22 11:25:47 0 [Note] InnoDB: Number of pools: 1
2022-12-22 11:25:47 0 [Note] InnoDB: Using SSE2 crc32 instructions
2022-12-22 11:25:47 0 [Note] InnoDB: Initializing buffer pool, total size = 16M, instances = 1, chunk size = 16M
2022-12-22 11:25:47 0 [Note] InnoDB: Completed initialization of buffer pool
2022-12-22 11:25:47 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=347122
2022-12-22 11:25:47 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2022-12-22 11:25:47 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2022-12-22 11:25:47 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2022-12-22 11:25:47 0 [Note] InnoDB: Setting file 'C:\xampp\mysql\data\ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2022-12-22 11:25:47 0 [Note] InnoDB: File 'C:\xampp\mysql\data\ibtmp1' size is now 12 MB.
2022-12-22 11:25:47 0 [Note] InnoDB: Waiting for purge to start
2022-12-22 11:25:47 0 [Note] InnoDB: 10.4.27 started; log sequence number 347131; transaction id 344
2022-12-22 11:25:47 0 [Note] InnoDB: Loading buffer pool(s) from C:\xampp\mysql\data\ib_buffer_pool
2022-12-22 11:25:47 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-12-22 11:25:47 0 [Note] InnoDB: Buffer pool(s) load completed at 221222 11:25:47
2022-12-22 11:25:47 0 [Note] Server socket created on IP: '::'.
2022-12-22 16:45:46 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2022-12-22 16:45:46 0 [Note] InnoDB: Uses event mutexes
2022-12-22 16:45:46 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2022-12-22 16:45:46 0 [Note] InnoDB: Number of pools: 1
2022-12-22 16:45:46 0 [Note] InnoDB: Using SSE2 crc32 instructions
2022-12-22 16:45:46 0 [Note] InnoDB: Initializing buffer pool, total size = 16M, instances = 1, chunk size = 16M
2022-12-22 16:45:46 0 [Note] InnoDB: Completed initialization of buffer pool
2022-12-22 16:45:46 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=347122
2022-12-22 16:45:46 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2022-12-22 16:45:46 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2022-12-22 16:45:46 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2022-12-22 16:45:46 0 [Note] InnoDB: Setting file 'C:\xampp\mysql\data\ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2022-12-22 16:45:46 0 [Note] InnoDB: File 'C:\xampp\mysql\data\ibtmp1' size is now 12 MB.
2022-12-22 16:45:46 0 [Note] InnoDB: Waiting for purge to start
2022-12-22 16:45:46 0 [Note] InnoDB: 10.4.27 started; log sequence number 347131; transaction id 344
2022-12-22 16:45:46 0 [Note] InnoDB: Loading buffer pool(s) from C:\xampp\mysql\data\ib_buffer_pool
2022-12-22 16:45:46 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-12-22 16:45:46 0 [Note] InnoDB: Buffer pool(s) load completed at 221222 16:45:46
2022-12-22 16:45:46 0 [Note] Server socket created on IP: '::'.
2022-12-22 16:46:10 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2022-12-22 16:46:10 0 [Note] InnoDB: Uses event mutexes
2022-12-22 16:46:10 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2022-12-22 16:46:10 0 [Note] InnoDB: Number of pools: 1
2022-12-22 16:46:10 0 [Note] InnoDB: Using SSE2 crc32 instructions
2022-12-22 16:46:10 0 [Note] InnoDB: Initializing buffer pool, total size = 16M, instances = 1, chunk size = 16M
2022-12-22 16:46:10 0 [Note] InnoDB: Completed initialization of buffer pool
2022-12-22 16:46:10 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=347156
2022-12-22 16:46:10 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2022-12-22 16:46:10 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2022-12-22 16:46:10 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2022-12-22 16:46:10 0 [Note] InnoDB: Setting file 'C:\xampp\mysql\data\ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2022-12-22 16:46:10 0 [Note] InnoDB: File 'C:\xampp\mysql\data\ibtmp1' size is now 12 MB.
2022-12-22 16:46:10 0 [Note] InnoDB: Waiting for purge to start
2022-12-22 16:46:10 0 [Note] InnoDB: 10.4.27 started; log sequence number 347165; transaction id 344
2022-12-22 16:46:10 0 [Note] InnoDB: Loading buffer pool(s) from C:\xampp\mysql\data\ib_buffer_pool
2022-12-22 16:46:10 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-12-22 16:46:10 0 [Note] Server socket created on IP: '::'.
2022-12-22 16:46:10 0 [Note] InnoDB: Buffer pool(s) load completed at 221222 16:46:10
2022-12-22 16:48:39 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2022-12-22 16:48:39 0 [Note] InnoDB: Uses event mutexes
2022-12-22 16:48:39 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2022-12-22 16:48:39 0 [Note] InnoDB: Number of pools: 1
2022-12-22 16:48:39 0 [Note] InnoDB: Using SSE2 crc32 instructions
2022-12-22 16:48:39 0 [Note] InnoDB: Initializing buffer pool, total size = 16M, instances = 1, chunk size = 16M
2022-12-22 16:48:39 0 [Note] InnoDB: Completed initialization of buffer pool
2022-12-22 16:48:39 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=347174
2022-12-22 16:48:39 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2022-12-22 16:48:39 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2022-12-22 16:48:39 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2022-12-22 16:48:39 0 [Note] InnoDB: Setting file 'C:\xampp\mysql\data\ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2022-12-22 16:48:39 0 [Note] InnoDB: File 'C:\xampp\mysql\data\ibtmp1' size is now 12 MB.
2022-12-22 16:48:39 0 [Note] InnoDB: Waiting for purge to start
2022-12-22 16:48:39 0 [Note] InnoDB: 10.4.27 started; log sequence number 347183; transaction id 344
2022-12-22 16:48:39 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-12-22 16:48:39 0 [Note] InnoDB: Loading buffer pool(s) from C:\xampp\mysql\data\ib_buffer_pool
2022-12-22 16:48:39 0 [Note] Server socket created on IP: '::'.
2022-12-22 16:50:58 0 [Note] InnoDB: Mutexes and rw_locks use Windows interlocked functions
2022-12-22 16:50:58 0 [Note] InnoDB: Uses event mutexes
2022-12-22 16:50:58 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2022-12-22 16:50:58 0 [Note] InnoDB: Number of pools: 1
2022-12-22 16:50:58 0 [Note] InnoDB: Using SSE2 crc32 instructions
2022-12-22 16:50:58 0 [Note] InnoDB: Initializing buffer pool, total size = 16M, instances = 1, chunk size = 16M
2022-12-22 16:50:58 0 [Note] InnoDB: Completed initialization of buffer pool
2022-12-22 16:50:58 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=347192
2022-12-22 16:50:58 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2022-12-22 16:50:58 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2022-12-22 16:50:58 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2022-12-22 16:50:58 0 [Note] InnoDB: Setting file 'C:\xampp\mysql\data\ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2022-12-22 16:50:58 0 [Note] InnoDB: File 'C:\xampp\mysql\data\ibtmp1' size is now 12 MB.
2022-12-22 16:50:58 0 [Note] InnoDB: Waiting for purge to start
2022-12-22 16:50:59 0 [Note] InnoDB: 10.4.27 started; log sequence number 347201; transaction id 344
2022-12-22 16:50:59 0 [Note] InnoDB: Loading buffer pool(s) from C:\xampp\mysql\data\ib_buffer_pool
2022-12-22 16:50:59 0 [Note] Plugin 'FEEDBACK' is disabled.
2022-12-22 16:50:59 0 [Note] Server socket created on IP: '::'.
Neemobeer
Cloud Security Engineer
Dumping a log and not providing any detail is not really helpful. Plus there are no errors in the log dump, so I suggest providing more detail.
