Windows 7 Need help with burning to a DVD! What Size DVD Do I Need?!?
SonicNitro
Just downloaded Windows 7 RC 64bit and do not know what size DVD to burn it to. May I have Some Help Please?
The 64-bit ISO file is around 3.05 GB, so you should be fine burning it onto any common DVD-R(W). Most of them are around ~4.7 GB which is more than enough.
Just make sure your DVD's capacity is at least 3.05 GB (which it probably is, unless it's a CD) and you'll be fine. :rolleyes:
I'd recommend doing a clean install.. ;) Just remember to back up all your personal files first.. ;)
