shota159
Since I started using Windows (about 14 years ago), I've always encountered numerous problems that prevented my computer from booting. I believe you may have experienced these issues too. To address this, many developers have created modified bootable Windows systems that allow users to recover their files, diagnose disk problems, scan for viruses, and more.
Based on my own experience, the best modified Windows system is HBCD PE or Hiren's BootCD PE, which includes all these features and more, with over 60 tools. The system is only 3 GB in size and requires 2 GB of RAM. You can easily use it by burning it to a DVD using a program like UltraISO or to a USB drive using Rufus.
Download : HBCD PE
Hiren's BootCD PE is indeed a powerful toolkit for system recovery, diagnostics, and troubleshooting. It includes a broad collection of utilities that can help recover files, diagnose disk issues, scan for viruses, and perform various other maintenance tasks on a Windows system.
Using Hiren's BootCD PE:​
Here's a step-by-step guide on how to create a Hiren's BootCD PE using either a DVD or USB drive.
Option 1: Creating a bootable USB drive with Rufus
  • Download Hiren's BootCD PE:
  • Navigate to the https://www.hirensbootcd.org/ and download the "ISO" file. [*Download Rufus:
  • Go to the https://rufus.ie/ and download the latest version of Rufus. [*Prepare the USB Drive:
  • Insert a USB drive with at least 4 GB of storage into your computer (Note: Ensure that no important data is on the USB drive, as it will be formatted during the process). [*Open Rufus:
  • Run the Rufus utility. No installation is required as it is a portable application. [*Select the USB Drive and ISO:
  • In Rufus:
  • Device: Select your USB drive.
  • Boot selection: Click “SELECT” and choose the Hiren's BootCD PE ISO file you downloaded earlier.
  • Partition scheme: Select MBR for BIOS/UEFI compatibility.
  • File system: Ensure it's set to FAT32. [*Start the Installation:
  • Click “START” and confirm any prompts to proceed with formatting the USB drive and copying the files. This will create a bootable USB drive with Hiren's BootCD PE.
Option 2: Creating a bootable DVD with UltraISO
[*Download and Install UltraISO:
  • Download UltraISO from its official website and install it on your computer. [*Download Hiren's BootCD PE:
  • Navigate to the https://www.hirensbootcd.org/ and download the "ISO" file. [*Prepare the DVD:
  • Insert a blank DVD (or one that can be overwritten) into your DVD drive. [*Open UltraISO:
  • Run UltraISO as an administrator. [*Open the Hiren ISO:
  • In UltraISO:
  • Click on “File” > “Open”.
  • Select the Hiren's BootCD PE ISO file you downloaded. [*Burn the ISO to DVD:
  • Click on “Tools” > “Burn CD/DVD Image”.
  • Ensure your DVD drive is selected in the 'Drive' dropdown.
  • Verify the ISO is listed under 'Image File'.
  • Click “Burn” to start the burning process.
Booting from Hiren's BootCD PE:​
[*Insert the Bootable USB or DVD:
  • Insert the created USB drive or DVD into the computer you need to diagnose or recover. [*Access the Boot Menu:
  • Reboot the computer and immediately press the key to access the boot menu (commonly F12, F11, ESC, or DEL depending on the system manufacturer). [*Select the Boot Device:
  • Choose the USB drive or DVD from the boot menu and press Enter.
  • Boot into Hiren's BootCD PE:
  • Your system will boot into Hiren's BootCD PE. You can start diagnosing issues, recovering files, or using any of the many tools included in the environment.
Key Tools in Hiren's BootCD PE:​
  • File Recovery:
  • Tools like Recuva help recover deleted files.
  • Disk Diagnostics:
  • Hard drive health checks and diagnostics tools like HD Tune.
  • Virus Scanning:
  • Malware removal tools such as Malwarebytes and more.
  • System Utilities:
  • Partition management tools like AOMEI Partition Assistant.
  • Backup and recovery tools like Macrium Reflect. Hiren's BootCD PE can be a lifesaver in many situations, from simple file recovery to complex system diagnostics. Whether you choose to use a USB or a DVD, Hiren's BootCD PE provides a comprehensive toolkit for maintaining and troubleshooting Windows systems.
