xc0n
hey guys ive got windows 7 ultimate 64bit installed everything is working fine, yesterday i brought a digital tv card, its a kworld Plus TV PCI PRO model number: KW-PC160-T the driver works fine but the software it comes with wont work with windows 7 so i use windows media center and it works fine, but the remote control wont work with windows media center, i went in remote controll setting and set it to windows media center edition but when i press a button it says " please re-initialize the Remote Panel settings to launch application?? anyone know why the remote wont work with media center is there any driver update / tweak i can do to fix this?
It seems like you're having trouble with getting your remote control to work properly in Windows Media Center with your Kworld Plus TV PCI PRO card on Windows 7 Ultimate 64-bit. Here are some steps you can take to troubleshoot and possibly fix the issue:
Troubleshooting Steps:​
  1. Check Remote Control Battery:
    • Ensure the batteries in your remote control are functional and properly installed. Weak batteries can cause communication issues.
    []Update Remote Control Drivers:
    • Check if there are updated drivers or software for your remote control specifically designed for Windows 7. Visit the manufacturer's website for any driver updates.
    ]Reconfigure Remote in Windows Media Center:...
    • Try reconfiguring the remote control settings in Windows Media Center:
      • Open Windows Media Center.
      • Navigate to Tasks > Settings > General > Windows Media Center Setup > Set Up Your Remote.
      • Follow the on-screen instructions to set up your remote control.
    []Check Compatibility with Windows 7:
    • Confirm that the remote control is compatible with Windows 7. Some older remotes may not work properly with newer operating systems.
    ]Third-Party Software:
    • Consider using third-party software that is compatible with your remote control and Windows 7. Some third-party applications offer better remote control support.
    []Contact Manufacturer Support:
    • If the issue persists, reach out to Kworld's support for assistance. They might provide additional guidance or updates to resolve the problem.
    ]Additional Resources:
    • Check online forums and community threads related to Kworld Plus TV PCI PRO and Windows 7. Others may have encountered and solved similar issues.
      Additional Information:​
    • If you require further assistance, feel free to provide more details or ask specific questions to help narrow down the issue and find a solution tailored to your setup. By following these steps, you should be able to troubleshoot and hopefully resolve the problem with your remote control in Windows Media Center.
