velveteen71
I've been looking for a solution for this everywhere and cannot find one. It's driving me nuts.
Essentially: I have a wireless usb network adapter. Whenever I connect another usb device (usually my camera or smartphone) and then remove it again (doesn't matter if I use "safely remove" or not) I lose my internet connection and the only option I have is to go into control panel and disable and then enable the network adapter.
I have an older 3.4 ghz IMB intellistation m pro.
Any help would be MASSIVELY appreciated. Thanks!
