Not allowed dual display?
I am a rank amateur first of all. I just installed windows 7 on my laptop which is a dual core, 2gb memory compaq. It works flawlessly and I love it.
Well, I am nearing an upgrade to my pc, which is just a bit outdated. It's specs are as follows:
Pentium 4: 2.19 ghz
1.5 gb memory
I have two flatpanel monitors; one is a 22 inch acer and the other is a 19 inch hp.
I have a cheap custom video card, an nvidia geforce mx4000 and I'm not sure what the video driver on my motherboard is.
I have been running XP on this pc and I have had a dual monitor display for a long time. After I installed Windows 7, only one of my monitors is being detected. It is the one connected to my nvidia card.
I did a little research and found that pressing win + p should give me the option to connect a second monitor, but that did not work. In fact, I am only allowed a very conservative display resolution of 1280 x 1024.
In device manager there is a video controller that has no driver installed, and I have been unable to install a driver using windows 7 options.
I've included a couple of screenshots of my system which hopefully will allow you technical geniuses to help me out.
Also, my laptop will display two monitors just fine. I can connect the monitor that is not being detected on my pc and all the relevant options become available.
Help! Thanks!
http://img268.imageshack.us/i/devicemanager.png/
http://img268.imageshack.us/i/screenoptions.png/
