The Merg
I have Windows 7 Home Premium 64-bit SP1 installed. I noticed the other day that while the Network Connection icon in my system tray looks fine, if I click on it I get a notification that I am not connected to a network. The issue is that I am connected to my network and the Internet.
If I open up the Network and Sharing Center it says that I am not connected to any networks and gives me the option to connect to a network. If I look at the Network Map, it shows my two PC's and all my other devices and the connection to the switch I am connected, but shows no connection to my gateway/router and the Internet.
I have two Ethernet adapters installed in my PC (on the system board). I have disabled the one that I am not using.
Here are some of the things that I have tried to resolve the issue:
  • Uninstall and reinstall the Ethernet adapters
  • Uninstall, to include the drivers, and reinstall the Ethernet adapters
  • Disabling IPV6 from the ethernet adapters
  • Installing a wireless adapter
    • The same issue appears for this - says not connected, but I am
  • Windows 7 Repair Install
  • System Restore - failed, which led me to doing the Windows 7 Repair Install
  • sfc /scannow to check for issues - nothing found
  • Network Troubleshooting - nothing found
  • Switching to the other Ethernet adapter
  • Rebooting the switch
  • Rebooting the router
I've searched around on the Internet and cannot seem to find a solution that works.
Any help that you can provide would be appreciated.
Thanks,
Merg
It seems like you've tried several troubleshooting steps to fix the issue with your network connection on Windows 7 Home Premium 64-bit SP1 without success. Since the problem persists even after attempting various solutions, let's explore some additional steps to help resolve this network connectivity issue. Here are some advanced troubleshooting steps you can try:
1. Update Network Adapter Drivers:​
  • Ensure that your network adapter drivers are up to date. Visit the manufacturer's website to download the latest drivers and install them.
    2. Check Network Services:​
  • Verify that essential network-related services are running properly. To do this:
    • Press Win + R, type services.msc, and hit Enter...
    • Check services like "Wired AutoConfig," "Network Location Awareness," and "Network List Service." Ensure they are set to Automatic.
      3. Reset TCP/IP Stack:​
    []Open Command Prompt as an administrator and run the following commands:
     netsh int ip reset resetlog.txt netsh winsock reset
    4. Check Firewall and Antivirus:​
    ]Temporarily disable your firewall and antivirus software to see if they are causing the issue.
    5. Check Network Configuration:​
    []Verify that your network settings are correct, including IP address configuration, gateway settings, and DNS servers.
    6. Try Safe Mode with Networking:​
    ]Boot into Safe Mode with Networking to see if the issue persists. This will help to isolate if any third-party software is causing the problem.
    7. Network Adapter Settings:​
    []Check the properties of your network adapter in Device Manager. Ensure that settings like IPv4 configurations are correct.
    8. Perform a Clean Boot:​
    ]Use the System Configuration tool (msconfig) to perform a clean boot, disabling non-essential services and startup items. After attempting these steps, restart your computer and check if the network connection issue is resolved. If the problem still exists, there may be a deeper underlying issue with the operating system or hardware that requires further diagnosis. Feel free to try out these steps, and let me know if you encounter any specific issues or need further assistance along the way!
