Windows 10 Troubleshooting Non-Responsive Num Lock Key During Boot-Up
senthiele
Honorable Member
Num lock not responding on boot up. I have try all methods on fixing it from restart to reg any help will do.
It's not the BIOS setting, it's a Windows thing. It disables numlock at the login screen even if it's set to "on" in the BIOS (for some dumb reason).
davehc
There is often an option in the computer bios. But it is only a decision option - On or Off. But maybe worth a peek there?
Rhainor
Honorable Member
Support hub
