Octane render and vram
MicLarc87
Hi everybody. I'm new here. I write this post here because i can't have any answer on feedback hub and tech support.
I use Octane Render and i have two 3080 ti (12gb) but i know that the WDDM make unavailable about 33% of vram.
I've already asked to Octane and Nvidia team but they said what i know. WDDM problem.
There's someone of you that know how to solved this problem?
Thanks for your help
Probably a question you want to pose to Microsoft.
If you are talking about Windows dedicating a portion of vram, that is normal, and as far as I know there is no way to adjust the amount dedicated to the OS. Windows has complete control of that.
Neemobeer
Windows Forum Team
MicLarc87
Maybe my English is quite bad and sorry for that. I write this post here because i can't have any answer on feedback hub and tech support!
I know windows dedicating a portion of vram and it's about 500mb (more or less). The problem is about the amount of unvailable vram while using octane render (33%)
Neemobeer
Windows Forum Team
Ahh gotcha. Seems like a problem then between WDDM and Octane Render which unfortunately is probably more specialized support needs than can be offered here.
