Windows 8 Odd Problem In networking..
Anshay Sardana
Hi...I'm Anshay.
I've got an odd problem to experience in Windows 8 Release Preview 64-bit after upgrading from Windows 7 Home Basic 64-bit.
It is detecting my WiFi Network..and i can access it through Windows 8 Metro Apps but i can't access it through any of the softwares that i have installed like Google Chrome,Firefox,Google Drive,UTorrent etc.
I'm typing this message from another person's computer on which, too, the same OS is installed but surprisingly there are no such problems arising on his machine.
Please Help me..
Sorry, you are absolutely correct Windows Defender is native. Sometimes I forget which forum I'm working in. Thanks for straightening me out on that one.
Frankly I'm running out of suggestions, except some information regarding your router. Check to see if there is a possible firmware update that may address the issue.
Try running it briefly without security (open) no encryption to check if there is potential overhead issues or other problems relating to the encryption you've chosen.
Select another channel at the extremes of what might be available Channel three (3) or eleven (11)
Disable IPv6 in the properties of your wireless network adapter.
Try safemode with networking by tapping the F8 key during POST
You never commented on...
Open Chrome and type this
209.85.145.105
into the URL address bar (not search bar) and hit enter
Let us know the results
209.85.145.105
I don't have chrome but I tried this in firefox,safari and even IE in the softwares not the Win8 Apps...but nothing is happening after loading that URL up...it's simply blinking every time I press Enter.
Sorry but you can understand my confusion.
Open a command prompt and type
ipconfig /all | clip (the vertical line is the pipe symbol usually found above the backslash key on your keyboard)
and hit enter
click reply to this thread and then paste the contents of your clipboard (the results of the previous command) into it and let's see what you've got.
and hit enter
Thanx fr ur response!!
But after typing in this command and pressing in Enter, it is showing a blank space and changing d line...
The command doesn't produce anything in the command prompt window. It simply copies information to the Windows clipboard.
Just paste (ctrl + V) into your next post
Windows IP Configuration
Host Name . . . . . . . . . . . . : Anshay-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Local Area Connection* 11:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 16-6D-57-4A-59-9A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection 0:
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 20-6A-8A-80-F8-38
Wireless LAN adapter Wi-Fi 0:
Description . . . . . . . . . . . : Qualcomm Atheros AR5BWB222 Wireless Network Adapter
Physical Address. . . . . . . . . : 44-6D-57-4A-59-9A
Link-local IPv6 Address . . . . . : fe80::7070:46e5:bd35:2f95%12(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 04 August 2012 00:23:15
Lease Expires . . . . . . . . . . : 05 August 2012 00:23:15
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 457469271
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-41-55-57-20-6A-8A-80-F8-38
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{40CF1BC1-3B32-4F49-896F-693F4481271D}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 14:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:24c0:52f:3f57:fefc(Preferred)
Link-local IPv6 Address . . . . . : fe80::24c0:52f:3f57:fefc%16(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
open a command prompt again and type
ping 192.168.1.1
hit enter and let us know the results
type
ping 209.85.145.105
type
http://www.google.com
Basically we are looking for sent 4 received 4 lost 0
ping 192.168.1.1
type
ping 209.85.145.105
type
ping Google
Well, yes I am getting "sent 4 received 4 lost 0" both the times..but when I type in "ping Google", it is saying: "Ping request could not find host Google.Please check the name and try again."
ping 192.168.1.1
type
ping 209.85.145.105
type
ping Google
Well, yes I am getting "Sent 4 Received 4 Lost 0" both the times but when I enter in "ping Google", it says,"Ping request could not find host Google.Please check the name and try again".
OK, you can ping google's IP address but cannot resolve its' FQDN. So that means you are having DNS issues.
One more thing to try first
Click start and in the windows search box type
[B][I][SIZE=3]http://209.85.145.105[/SIZE][/I][/B]
Sorry I just noticed that every time I type
http://Anything That Follows
the site's text editor or software automatically assigns it a URL tag and shortens or edits the actual text that I type unless I surround it with CODE tags.
So please make sure that you
ping
www.google.com
and make sure that you type
into the search or run dialog box.
ping
www.google.com
Nothing solved...!!!
When you click the Start Button and type
and hit enter on your keyboard.......
What exactly happens?
Well, when I type this address in Run, my IE 'software' opens up and it says,"Page cannot be displayed"..means it is unable to connect.
Sort of but not exactly.
Close all browsers, especially IE
Open Control Panel, change the view by drop down in the top right corner to small icons
Open Internet Option
Select the Connections tab and then the LAN settings button, uncheck all check boxes there and OK your way back out of there.
Open IE and see if it connects
Update the driver for your Atheros AR5BWB222 from here Link Removed
If still no joy up load a copy of your System Information Utility and we'll have a look at potential problem causers.
Click start and type
msinfo32
hit enter
In the resultant window click file -> save
give it a name and choose a location to save it.
Zip it up and attach it to your next post.
