DigiDuncan
- Joined
- May 5, 2012
- Messages
- 4
- Thread Author
- #1
Oh my Notch.
So, I'm BSODing randomly. On only one user.
BSOD text:
Note the ntoskrnl.exe.
That's the problem.
But my research says that paticular file is... important.
Linked are my 5 latest dumps, the text above being form the latest one.
Any help would be, well, helpful.
Link Removed due to 404 Error
Thank you,
DigiDuncan
BSOD text:
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: ntoskrnl.exe
IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x0000000a (0x00000000000000dc, 0x0000000000000002, 0x0000000000000001,
0xfffff800032ff405)
*** ntoskrnl.exe - Address 0xfffff800032cf1c0 base at 0xfffff80003250000 DateStamp
0x4fa390f3
That's the problem.
Thank you,
DigiDuncan
