NettleWarbler
Honorable Member
I have an old Time (make computer ) , i put it in the old cupboard downstairs . It was working , i tried it yesterday and couldn't load windows . How can i see whats on the hard drives they are ribbon fitting's which i removed .
I don’t know what make of computer you mean but assuming it’s not damaged and working, you‘d need to plug it into a compatible interface in order to try and receive data. There are IDE to USB adapters (I’m assuming that’s the cable type you’re talking about, if not you’d need to look into something else) that you can use to open it on a more modern computer. I have never used this myself though.
Everytime I click on something I end up back on the original page .
Always goes back to the original web page .
Thanks ussnorway , when I put the mouse pointer near the iso file it says 553.0m and a download button appears . I never thought an iso image would be like a cd , I will see if I can download it . Thank you .
I downloaded it , it was 552 mb and it took a full hour to download . It says disc image file , I will try it later probably tomorrow I will burn it to cd .
just [right click] mount the iso and you can copy the driver folder to your desktop or some backup location
I use wondershare dvd creator for burning stuff , its not loaded yet i'm still trying to convert this new hard drive to gpt .
I tried wondershare dvd creator to burn a dvd , I also tried to burn a disc image each time it said no burner found , but in my pc it shows the dvd burner clearly .
ussnorway , will it work with drivers . When i load wondershare dvd creator , it usually dosn't need any help .I'v just tried wondershare dvd creator its exactly the same so somethings wrong .
How will i get the drivers , it says check for update every week .
i have no interest in wondershare dvd creator or any time for driver updaters
the drivers i sent you are the ones in the iso for your camera, just unzip the folder and run the setup.exe to install them
I got those drivers , thanks very much . I thought the drivers were for wondershare as that was not recognising my dvd drive , all i seem to do is make mistakes . I never thought you would send them to my email address .
