After a quick look your memory timings are miss set. They're set to 6-5-5-17 but should be set to 6-6-6-18 trc 24 Vdimm 1.80V. Shall now check the dump files.
Hi thanks 4 help...so what its mean? what should I do? my memory its damage? I run memtest and its pass 7-8 good...wotk a lot og hours without mistakes... how do i set my memory to CL 6 - 6-Trp 6-Tras 18 Trc 24 I don't now what its mean.../?
Ok, you need to go to your bios. Either Del or F2 to enter the bios. In the bios you need to find Memory timings page. Is probably in Advanced or advanced chipset in their you'll enter the memory timings as given.
It is an OEM Okay with oem system they lock down the bios's. Could you check the seating of the memory as maybe when changing the HDD it became loose. Or roll back to the previous bios.
