Windows 7 Pasword problem - ALT key
jolanabases
Today I set a pasword to my computer, with some letter from Latvian language. I should press ALT+a to get "ā"...
Everything was working fine, until now..
Now when I try to type in password at welcome screen, the ALT button doesn't work - I simply can't get my symbol and I don't know why...
What should I do? :(
You can also try to boot in save mode: press F8 several times during the power up sequence. Than you will see startup options, select Save Mode. Startup will take a long time, with all kind of messages, but eventually you will get a change to select a user. If you are lucky you will see a new user Administrator, try that one without password. Change back the password of your account.
Hope this will do the trick
bochane
101 Alt-X does it in Windows (the numbers 1 0 1 followed by Alt and x together). I don't know whether this works in the password. I don’t dare to check it, but will keep my fingers crossed.
bochane
