Windows 7 PC requests password on wakeup, even though my power settings say "No"
Blaq
Hi folks,
This week (possibly after an automatic upgrade), my Windows 7 PC changed its sleep behaviour. Previously, it would emerge from sleep mode without going to the login screen. As of ~4 days ago, it now does.
I double-checked Power Options' Advanced Settings. For every power plan, "Require a password on wakeup" is still set to No.
What else may be causing my PC to ask for a password on wakeup?
Control Panel\All Control Panel Items\Power Options
Select link from left column = "Require a password on wakeup"
Then click the link that says "Change settings that are currently unavailable"
Should go live and allow change.
Also double check your screen saver options and make sure you don't have
On resume, display logon screen checked.
Regards
Randy
Try setting it to use password and accept and close window then open it back up and change to no password. Sometimes that works When Windows forgets a setting.
Joe
Uh-oh. At Control Panel\Hardware and Sound\Power Options\System Settings , the Password protection on wakeup choices are greyed out. Yet, I'm an Administrator user. How can that be?
Regards
Randy
Glad you got it sorted out. Thanks for the follow up and hope to continue to see you around the forum.
Regards
Randy
