Windows 10 Pixel format not accelerated
HalpMeh
Hello there. Im having an issue with Minecraft. Whenever i try to start it it displays the following crash log
---- Minecraft Crash Report ----
// Who set us up the TNT?
Time: 1/10/16 3:53 PM
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:252)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at bao.ag(SourceFile:340)
at bao.f(SourceFile:713)
at net.minecraft.client.main.Main.main(SourceFile:148)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.7.10
Operating System: Windows 10 (amd64) version 10.0
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 42295072 bytes (40 MB) / 127139840 bytes (121 MB) up to 1060372480 bytes (1011 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.7.10
LWJGL: 2.9.1
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs: []
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Vec3 Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Anisotropic Filtering: Off (1)
I have tried everything i can think of. The help sites i have went too have told me to use DxDiag and update my drivers but the only thing it displays is Microsoft Basic Display Driver with a publisher of N/A. Please help.
- Much obliged,
Me.
The problem is most likely that you do not have a display driver installed or is not installed correctly. The fact that you state it says Microsoft Basic Display Driver, means it is not installed.
What's the make/model of your computer and video card?
I have an Acer Aspire X1200 Desktop and the make/model of the card will not display...
Here is the info from DxDiagnostics
Name: Microsoft Basic Display Driver
Manufacturer: n/a
Chip Type: n/a
DAC type: n/a
Device Type: Display-Only Display device
I'd try Linux (Link Removed) but it's up to you.
well, "NVIDIA Installer cannot continue" that sucks... just took a look inside my pc and there isn't even a card... i dont know how it got taken out but it did. sorry for wasting your time...
