Windows 7 portcls.sys and other porblems.
Martian
Let me start by saying. I posted here once before. During the time I posted 4 other threads had people actively trying to help people who didn't have enough respect for you guys to even read the forums and sub-forum rules. All while I, who posted proper, was left with a middle finger. I'm hoping for a better turn out. :)
I am stuck. I have tried without success a number of fixes on numerous BSOD that all relate to portcls. I am aware this is usually an onboard audio problem. I disabled ac97 in BIOS, but to no avail. I am thinking it is something else plugged into a usb or plugged into the monitor that can not be processed. Maybe the fan controller? or perhaps the dvd drive is too old. I do not know.
I made it a .rar. It was easier that way. thanks.Link Removed
There just aren't very many people who help analyze BSOD's for users.
We are not ignoring you - we are just too busy to take care of all these issues on all the forums that we post at.
Recently the community lost one of it's most productive members because he became burnt out - and now isn't doing any BSOD's at all!
If we don't respond to your posts, please send one of us a PM.
Please rerun the report collection app here: Link Removed
Your upload doesn't contain all of the reports that we use (in particular I use the MSINFO32.nfo report to screen for problem areas).
What settings did you use when you ran Driver Verifier?
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the...
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] Link Removed [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): Link Removed
Alternate link: Disc-Tools.com
Manual procedure here: Link Removed - Invalid URL
AsIO.sys Mon Apr 6 03:21:08 2009 (49D9AD64)
Asus PCProbe Utility
Rt64win7.sys Fri May 22 10:52:30 2009 (4A16BC2E)
Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC
If the above fixes don't stop the BSOD's, please post back with the latest memory dumps and we'll move on from there.
Analysis:
[FONT=lucida console]**************************Mon Sep  3 22:27:42.898 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090312-30217-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 0:02:21.022[/B]
BugCheck Code: [B]BugCheck D6, {fffff98033867000, 1, fffff88007790124, 0}[/B]
*** WARNING: Unable to verify timestamp for dump_wmimmc.sys
*** ERROR: Module load completed but symbols could not be loaded for dump_wmimmc.sys
Probably caused by :[B]dump_wmimmc.sys ( dump_wmimmc+22124 )[/B]
BugCheck Info: [B]DRIVER_PAGE_FAULT_BEYOND_END_OF_ALLOCATION (d6)[/B]
BUGCHECK_STR:  0xD6
PROCESS_NAME: [B]GameMon64.des[/B]
FAILURE_BUCKET_ID: [B]X64_0xD6_dump_wmimmc+22124[/B]
CPUID:        "Intel(R) Core(TM) i5 CPU         750  @ 2.67GHz"
MaxSpeed:     2670
CurrentSpeed:[B]2675[/B]
  BIOS Version                  2003
  BIOS Release Date             12/14/2010
**************************Mon Sep  3 22:13:16.544 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090312-24414-01.dmp]
System Uptime:[B]0 days 3:28:31.652[/B]
BugCheck Code: [B]BugCheck D6, {fffff980805f5000, 1, fffff880087cd124, 0}[/B]
BUGCHECK_STR:  0xD6
MaxSpeed:     2670
  BIOS Version                  2003
**************************Mon Sep  3 18:07:21.317 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090312-23992-01.dmp]
System Uptime:[B]0 days 0:01:56.800[/B]
BugCheck Code: [B]BugCheck C4, {e3, fffffa8009432531, 6b1f300, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!VerifierBugCheckIfAppropriate+3c )[/B]
BugCheck Info: [B]DRIVER_VERIFIER_DETECTED_VIOLATION (c4)[/B]
BUGCHECK_STR:  0xc4_e3
PROCESS_NAME: [B]ekrn.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xc4_e3_nt!VerifierBugCheckIfAppropriate+3c[/B]
MaxSpeed:     2670
CurrentSpeed:[B]2674[/B]
  BIOS Version                  2003
**************************Mon Sep  3 18:04:11.110 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090312-28828-01.dmp]
System Uptime:[B]0 days 3:32:05.219[/B]
BugCheck Code: [B]BugCheck C4, {e3, fffffa8009832531, 6abed58, 0}[/B]
MaxSpeed:     2670
  BIOS Version                  2003
**************************Mon Sep  3 14:31:17.274 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090312-29031-01.dmp]
System Uptime:[B]0 days 0:06:12.382[/B]
BugCheck Code: [B]BugCheck C4, {e3, fffffa8009621531, 6bff0a0, 0}[/B]
MaxSpeed:     2670
  BIOS Version                  2003
**************************Mon Sep  3 14:23:41.844 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090312-29936-01.dmp]
System Uptime:[B]0 days 4:03:55.343[/B]
BugCheck Code: [B]BugCheck C4, {e3, fffffa8009d79531, 699ed98, 0}[/B]
MaxSpeed:     2670
  BIOS Version                  2003
**************************Mon Sep  3 01:27:47.882 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090312-31184-01.dmp]
System Uptime:[B]0 days 0:02:43.990[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff88004bd5bf9, fffff880067b5b20, 0}[/B]
*** WARNING: Unable to verify timestamp for ctaud2k.sys
*** ERROR: Module load completed but symbols could not be loaded for ctaud2k.sys
*** ERROR: Module load completed but symbols could not be loaded for ksthunk.sys
Probably caused by :[B]portcls.sys ( portcls!PcNewInterruptSync+cbf1 )[/B]
BugCheck Info: [B]SYSTEM_SERVICE_EXCEPTION (3b)[/B]
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]audiodg.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_portcls!PcNewInterruptSync+cbf1[/B]
MaxSpeed:     2670
  BIOS Version                  2003
**************************Mon Sep  3 01:23:52.444 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090312-33103-01.dmp]
System Uptime:[B]0 days 0:02:25.552[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff8800466cbf9, fffff88006399b20, 0}[/B]
BUGCHECK_STR:  0x3B
MaxSpeed:     2670
  BIOS Version                  2003
**************************Mon Sep  3 01:20:34.223 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090312-30186-01.dmp]
System Uptime:[B]0 days 1:59:12.347[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff8800475abf9, fffff88006c05b20, 0}[/B]
BUGCHECK_STR:  0x3B
MaxSpeed:     2670
  BIOS Version                  2003
**************************Sun Sep  2 23:20:35.206 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090212-29764-01.dmp]
System Uptime:[B]0 days 0:25:46.005[/B]
BugCheck Code: [B]BugCheck C4, {83, 3b209170, 4, 3b209}[/B]
*** WARNING: Unable to verify timestamp for speedfan.sys
*** ERROR: Module load completed but symbols could not be loaded for speedfan.sys
Probably caused by :[B]speedfan.sys ( speedfan+20d5 )[/B]
BUGCHECK_STR:  0xc4_83
PROCESS_NAME: [B]speedfan.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xc4_83_speedfan+20d5[/B]
MaxSpeed:     2670
  BIOS Version                  2003
**************************Sun Sep  2 22:55:18.715 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\090212-29250-01.dmp]
System Uptime:[B]0 days 0:01:33.823[/B]
BugCheck Code: [B]BugCheck C4, {e3, fffffa800a07a531, 68eeed0, 0}[/B]
MaxSpeed:     2670
  BIOS Version                  2003
[/FONT]
3rd Party Drivers:The following is for information purposes only. Any drivers in red should be updated.
[B]AsIO.sys            Mon Apr  6 03:21:08 2009 (49D9AD64)[/B]
[B]Rt64win7.sys        Fri May 22 10:52:30 2009 (4A16BC2E)[/B]
intelppm.sys        Mon Jul 13 19:19:25 2009 (4A5BC0FD)
ASACPI.sys          Wed Jul 15 23:31:29 2009 (4A5E9F11)
amdxata.sys         Fri Mar 19 12:18:18 2010 (4BA3A3CA)
emupia2k.sys        Wed Jul  7 09:38:03 2010 (4C34833B)
ctsfm2k.sys         Wed Jul  7 09:38:10 2010 (4C348342)
ctoss2k.sys         Wed Jul  7 09:38:24 2010 (4C348350)
ha20x22k.sys        Wed Jul  7 09:41:25 2010 (4C348405)
ctaud2k.sys         Wed Jul  7 09:42:14 2010 (4C348436)
ctprxy2k.sys        Wed Jul  7 09:42:17 2010 (4C348439)
CTEXFIFX.SYS        Wed Jul  7 09:44:03 2010 (4C3484A3)
CT20XUT.SYS         Wed Jul  7 09:44:15 2010 (4C3484AF)
CTHWIUT.SYS         Wed Jul  7 09:44:19 2010 (4C3484B3)
speedfan.sys        Fri Mar 18 12:08:46 2011 (4D83838E)
epfwwfpr.sys        Tue Jun 28 03:30:09 2011 (4E098301)
ehdrv.sys           Tue Jun 28 03:34:38 2011 (4E09840E)
eamonm.sys          Tue Aug  2 05:33:29 2011 (4E37C469)
LEqdUsb.Sys         Fri Sep  2 02:22:56 2011 (4E607640)
LHidEqd.Sys         Fri Sep  2 02:22:59 2011 (4E607643)
LHidFilt.Sys        Fri Sep  2 02:23:09 2011 (4E60764D)
LMouFilt.Sys        Fri Sep  2 02:23:15 2011 (4E607653)
LUsbFilt.Sys        Fri Sep  2 02:23:19 2011 (4E607657)
ao0gp5jc.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
nvlddmkm.sys        Wed Feb 29 13:04:52 2012 (4F4E68C4)
sptd.sys            Sat Mar  3 11:45:52 2012 (4F524AC0)
cpuz135_x64.sys     Fri Mar  9 03:56:55 2012 (4F59C5D7)
aikqeddf.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
ana2mwok.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
aabv2x2n.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
ajljni4m.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
ac8y2zyd.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
alp8wech.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
asj71tsb.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
hiber_ataport.sys   Mon Jul 13 19:19:47 2009 (4A5BC113)
alq32fc0.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
andrmi2p.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
avhbjhse.SYS        Tue Dec 27 17:30:45 2011 (4EFA4715)
[/FONT]
ao0gp5jc.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
aikqeddf.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
ana2mwok.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
aabv2x2n.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
ajljni4m.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
ac8y2zyd.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
alp8wech.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
asj71tsb.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
hiber_ataport.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. This is a Windows driver that's copied for use during hibernation/sleep transitions - if Windows Update is current, then there's no need to update the source driver (ataport.sys)
alq32fc0.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
andrmi2p.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
avhbjhse.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. Daemon Tools dynamically assigned driver.
