Windows 11 artwork featuring PowerToys and open-source tools with a GitHub icon.
Microsoft has quietly pushed out PowerToys v0.94.2 to stamp out a stubborn installer regression that left some users unable to upgrade or install the utility suite from GitHub, winget, or the Microsoft Store, restoring a critical path for distribution and deployment.
Background​
PowerToys has evolved from a nostalgic power-user toolkit into a polished, actively maintained set of utilities for Windows 10 and Windows 11. Recent months have seen a steady cadence of releases focused on UI polish, accessibility, and internal platform modernization. The v0.94 series introduced helpful features such as a settings search bar, a shortcut conflict detector, and the Gliding cursor mode for Mouse Pointer Crosshairs. Those functional improvements were widely welcomed — but deployment reliability briefly became a problem.
Shortly after v0.94 shipped, multiple install reports surfaced: installers would fail late in the bootstrap process with a Windows error referencing HRESULT 0x8007007e and a missing DLL or dependency. Microsoft reacted quickly with incremental releases: 0.94.1 attempted to address the issue, and a follow-up patch — v0.94.2 — was published to correct a missing vcruntime dependency that was blocking installations. The new build is small and focused, but it restores the basic expectation that users should be able to install PowerToys from any supported source.
What happened: the installer regression explained​
The symptom​
Users attempting to install PowerToys after the v0.94 release sometimes saw the installer fail with a bootstrapper error that included the code 0x8007007e and referenced a failed load of a bootstrapper function or DLL (reports cited a specific component named SilentFilesInUseBAFunction.dll). The failure could occur when installing:
  • From GitHub (standalone installer .exe)
  • Via winget / Windows Package Manager
  • From the Microsoft Store (App Installer/MSIX flow)
The error manifested whether the installer was run elevated or not, and it usually appeared late in the install process — after most of the package had been downloaded and after the bootstrapper attempted to load supporting runtime components.
The trigger​
Microsoft’s patch notes for v0.94.2 identify the proximate cause as a missing vcruntime dependency inside the installer bundle. In plain terms, one or more Visual C++ runtime artifacts that the bootstrapper expects to be present were not available or not packaged for some install scenarios, causing the bootstrapper to fail to load a helper DLL and abort the installation with 0x8007007e (module not found).
This is consistent with the classic meaning of 0x8007007E — the system could not find the specified module — but there are nuances: missing runtime dependencies can be the result of packaging decisions, build-toolchain changes, or differences between per-user vs. machine-wide installer images. Given PowerToys’ move to more modern installer tooling (the v0.94 release upgraded the installer to WiX 5 from WiX 3), the regression likely flowed from a packaging or dependency-handling gap introduced in that transition or in a follow-up build change.
Why it affected multiple delivery channels​
Three delivery paths were impacted:
  • GitHub .exe installers: These rely on the installer bundle (bootstrapper + payload) to include and load all required dependencies.
  • winget: When winget executes the installer, it runs the same bundled bootstrapper; if the bootstrapper’s runtime dependencies are missing, the installation aborts.
  • Microsoft Store / App Installer: Even though Store-installed apps may use different packaging (MSIX) or the Store pipeline, Store distribution still interacts with installers and runtime prerequisites. If a runtime expected by the installer isn’t present or registrable in the environment used by the Store’s installer agent, the same bootstrapper failure can occur.
Because the dependency problem is at the bootstrapper level — the common starting point for all install flows — it propagated to every supported install method.
What Microsoft changed in v0.94.2​
The v0.94.2 release is explicitly a targeted patch. The changelog entry describes a single fix:
  • Installer: Fixed the missing vcruntime dependency that blocked installations and caused the “Failed to load SilentFilesInUseBAFunction.dll (0x8007007e)” bootstrapper failure, restoring successful installs from GitHub, winget, and the Microsoft Store.
Operationally, that means the build artifacts for the installer were adjusted so that the Visual C++ runtime (or the correct runtime packaging/manifest entries) is available to the bootstrapper across all supported installation contexts. The patch was released as a small, focused update (new per-user and per-machine executables for x64 and ARM64) rather than bundling further feature or behavioral changes.
Technical analysis: root causes and contributing factors​
Packaging and runtime dependency management​
The most likely technical root cause was a packaging omission — either an absent runtime library, a manifest entry that failed to indicate a dependency, or a build configuration that excluded a needed runtime file for some installer variants.
  • Visual C++ redistributables (vcruntime) are common dependencies for native components in Windows software. If an installer includes native code or native helper DLLs that link against a specific vcruntime, the bootstrapper must ensure the runtime is present or bundled.
  • If the installer’s dependency chain includes a DLL that references vcruntime, but the bootstrapper lacks an explicit mechanism to stage or install that runtime prior to loading the DLL, a “module not found” error will result.
  • The move to WiX 5 (noted in the v0.94 release) is relevant: updating the installer platform can change the way dependencies are referenced or bundled. Upgrading installer tooling is good for security and maintainability, but it can introduce subtle packaging regressions during the transition.
Per-user vs. machine-wide instals and sandboxing​
Different install modes — per-user vs. machine-wide — have different permissions and runtime contexts. Likewise, winget and the Microsoft Store sometimes run installers inside sandboxed or service contexts with different environment variables and COM registration permissions.
  • A dependency that is presumed present in a full user session might not be visible in the system account or Store agent context.
  • Installer code that chooses between locating a system-wide runtime versus shipping a private runtime may fail to handle the system-agent scenario.
CI/CD, regression testing, and telemetry​
Large open-source projects with rapid release cadences can still ship regressions when test coverage for packaging scenarios is incomplete. A regression that affects installer behavior under certain channels (winget, Store, or machine vs. per-user contexts) implies that automated tests missed at least one of those execution paths.
  • Stronger CI that validates each artifact in the real install paths (user-elevated, system context, winget, Store) would catch this earlier.
  • Telemetry around installer failures (with opt-in user consent) can accelerate detection. Community bug reports did flag the problem quickly in this case, prompting the patch releases.
Risk assessment and impact​
End-user and power-user impact​
For most enthusiasts and hobbyists, an installer that aborts with a cryptic 0x8007007e error is an annoyance: it blocks access to new features and may shake confidence in reliability. For users who rely on winget, scripted provisioning, or enterprise deployment tooling, the problem is more than an annoyance — it can break automation.
  • Personal users: Might be forced to delay upgrade or attempt manual workarounds (install vcruntime manually, use different install modes).
  • Power users and sysadmins: Scripted installs via winget or deployment pipelines can fail silently or be flagged as a problematic deployment.
Enterprise considerations​
Enterprises deploying PowerToys at scale (via Intune, SCCM, or winget pipelines) need predictability. A transient packaging bug that stops installations can interrupt imaging or post-provisioning configuration scripts.
  • If the enterprise imaged machines with the older installer pre-configured, update steps might fail when run for the first time in the field.
  • Enterprises should verify installer success on a small cohort before broad rollout and consider pinning to a known-working version until the issue is validated.
Security posture​
A missing runtime dependency itself is not a direct security vulnerability, but the problem raises broader supply-chain considerations:
  • Packaging regressions can inadvertently alter the set of runtime components that are installed, which in turn changes the attack surface.
  • A rush to fix an installer regression must still account for code-signing, certificate validity, and integrity of redistributed runtimes.
Practical guidance: how to install or recover​
If you encountered the installer error prior to v0.94.2, here are practical steps to recover or install PowerToys reliably.
  1. Check your current version:
    • If PowerToys is already installed, open PowerToys Settings > Check for updates.
  2. For fresh installs, prefer the latest patch:
    • Download and run the patched per-user or machine-wide installer for your architecture (x64 or ARM64).
  3. Install via winget (works once the package is updated):
    • From an elevated PowerShell or Windows Terminal: winget install --id Microsoft.PowerToys --source winget
  4. If you must work around the issue before the patched build is available:
    • Install the appropriate Visual C++ runtime for your system (x64/ARM64) via Microsoft’s redistributable packages, then retry the PowerToys installer. This is a stop-gap and not ideal for scripted or automated deployments.
  5. If Store installation fails:
    • Retry after installing the latest patch; as a temporary workaround, use the GitHub installer or winget once the patch is published.
  6. Check the installer log if problems persist:
    • Use the installer’s /log switch to capture details and inspect for “module not found” entries and more precise failure points.
Note: Installing system redistributables manually can be disruptive in managed environments; coordinate with IT for enterprise devices.
What this means for PowerToys’ roadmap​
The v0.94.x series was a mix of functionality improvements and underlying modernization (WiX 5 installer upgrade). The quick fixes in 0.94.1 and 0.94.2 show a responsive maintenance approach. Looking forward, the upcoming v0.95 is expected to introduce heavier feature changes: a scheduled automatic theme-switching module for Windows 11 and a revamped Keyboard Manager UI.
These future changes have implications:
  • New modules (automatic theme switching) will increase the surface area of settings and runtime interactions; packaging and installer robustness must keep pace.
  • A redesigned Keyboard Manager suggests renewed attention to accessibility and usability, which could expand PowerToys’ audience — and thus increase the importance of reliable distribution.
Community reaction and support​
The community reaction was swift: users reported the install failures across GitHub issues, forums, and Q&A threads. Microsoft’s release of two follow-up builds in quick succession indicates they prioritized the fix. For projects with a broad user base, social proof and clear release notes are essential; the terse v0.94.2 changelog is factual but minimal — it gets the job done but leaves readers wanting more technical detail.
Users and IT professionals tend to respond better when maintainers:
  • Provide clear postmortems on regressions (what changed, why it failed, how it’s prevented going forward).
  • Publish compatibility notes for different delivery channels (GitHub, winget, Store).
  • Offer known-good installer hashes and guidance for mass deployment.
Recommendations for Microsoft and maintainers​
To reduce the likelihood and impact of similar regressions, the following measures are advisable:
  • Strengthen CI tests to include artifact validation across all supported install flows: user-elevated installer, machine installer, winget execution, and Store ingestion.
  • Add automated installation tests in sandboxed and system-agent contexts to catch differences between interactive and non-interactive installers.
  • Include explicit dependency manifests and a lightweight preflight check in the bootstrapper to detect missing runtimes before attempting to load native DLLs. Preflight checks give clearer error messages than cryptic bootstrapper load failures.
  • Maintain detailed release notes for patch builds that explain whether issues were packaging-only vs. code regressions.
  • Where feasible, adopt reproducible packaging and monitor installer telemetry (opt-in) to detect installation failures proactively.
How to verify you're safe after upgrading​
After installing v0.94.2, validate the installation:
  1. Open PowerToys Settings and confirm the app launches without warning dialogs.
  2. Use one or two modules (e.g., FancyZones, Keyboard Manager) to confirm functionality.
  3. If you deploy via winget or management tools, run a test on a small subset of machines first and monitor logs.
  4. Check the installer checksum or signature if you require artifact integrity verification.
Final assessment​
PowerToys v0.94.2 is a narrowly scoped but important fix: it restores the reliability of distribution channels and allows users to access recent feature improvements without hitting a hard stop during installation. The incident highlights the tight coupling between packaging and runtime dependencies — especially when installer platforms are modernized or when multiple distribution channels (GitHub, winget, Microsoft Store) all rely on a shared bootstrapper.
The quick cadence of 0.94.1 followed by 0.94.2 demonstrates effective triage and responsiveness from the maintainers. But the episode also emphasizes the need for more exhaustive packaging validation and clearer communication around installer regressions so that both individual users and enterprise IT teams can respond confidently.
For now, users who experienced the bootstrapper error should update to v0.94.2 or use winget with the patched package. Administrators should validate the fixed installer in their deployment pipelines and consider adding small pre-install checks for Visual C++ runtime presence where scripting is used.
PowerToys continues to be a valuable toolkit for Windows enthusiasts and administrators; the core lesson from this hiccup is operational: modernization (like WiX 5) is necessary, but only safe when coupled with comprehensive packaging and install-path testing.
Source: Neowin Microsoft fixes PowerToys install errors in another new v0.94.2 update
