Windows 7 problem with driver installation
chriz78
have problem with a unsigned driver
get message:
windows cant verify the publisher of this driver
but when i choose install anyway, same message occurs again and again.......
what should i do?
When you encounter the message "Windows can't verify the publisher of this driver" and selecting "Install anyway" does not resolve the issue, you can try the following steps to install the unsigned driver: 1. Disable Driver Signature Enforcement: This is a temporary solution to allow the installation of unsigned drivers. Here's how to do it: - Restart your computer. - During the boot process, before Windows loads, press and hold the "Shift" key while selecting "Restart". - Choose "Troubleshoot" > "Advanced options" > "Startup Settings" > "Restart". - After the restart, press the "7" or "F7" key to select "Disable driver signature enforcement". 2. Install the Driver in Test Mode: This method allows you to install the unsigned...
When you encounter the message "Windows can't verify the publisher of this driver" and selecting "Install anyway" does not resolve the issue, you can try the following steps to install the unsigned driver: 1. Disable Driver Signature Enforcement: This is a temporary solution to allow the installation of unsigned drivers. Here's how to do it: - Restart your computer. - During the boot process, before Windows loads, press and hold the "Shift" key while selecting "Restart". - Choose "Troubleshoot" > "Advanced options" > "Startup Settings" > "Restart". - After the restart, press the "7" or "F7" key to select "Disable driver signature enforcement". 2. Install the Driver in Test Mode: This method allows you to install the unsigned driver in Test Mode. Here's how: - Open an elevated Command Prompt. - Enter the command bcdedit /set testsigning on and press Enter. - Restart your computer and install the unsigned driver. 3. Use Driver Signature Enforcement Overrider Tool: You can use third-party tools like "Driver Signature Enforcement Overrider" to bypass driver signature enforcement. This tool allows you to load unsigned drivers by patching the Windows kernel. 4. Sign the Driver Yourself: If you have the technical knowledge, you can sign the driver yourself using a code signing certificate. This process involves generating a certificate, signing the driver, and installing the certificate on your system. Try these methods based on your comfort level with technical procedures. Remember that disabling driver signature enforcement can make your system vulnerable to malicious drivers, so proceed with caution.
