bmatias
I have a Windows Server 2008 R2 with IIS 6.2 with a default website published.
I have a url that is binded to the webserver, and when I access http://www.siteurl.com, I can reach the default page.
But I have a subfolder that I need to access a website but through url (www.siteurl.com/abc/def).
When I go with IP (internal - 192.168.x.x/abc/def or external - 111.111.111.111/abc/def), I can reach the webpage, but when I try http://www.siteurl.com/abc/def from outside I get an error that "The requested URL /abc/def/ was not found on this server.".
This is driving me crazy...
What can this be? What o I need to do to fix this dns/url/whatever misconfiguration?
Thanks a lot.
BM
Ok and you did mention the binding is setup and that works. Is /abc/def in the same physical path as the root default document and the group IIS_IUSRS has proper rights on that directory structure?
Neemobeer
Windows Forum Team
Is there a default document defined there?
bmatias
Yes... there is... that's why when i access using the ip address i get the expected result... but accessing by name, it's gives the error...
Neemobeer
Windows Forum Team
Does the URL work internally?
Neemobeer
Windows Forum Team
Neemobeer
Windows Forum Team
And also have you looked at the iis logs and event viewer?
bmatias
The event viewer and iis logs don't say anything usefull...
The folder has the correct permissions, and are subfolder of the root folder. So they inherited the permissions.
Neemobeer
Windows Forum Team
Do you have any kind of url redirection or header transforms?
bmatias
No... nothing of that...
I'm thinking it mmight be something related with binding or permissions for subfolders websites... but i can't reach any configuration refered to it...
Neemobeer
Windows Forum Team
I'd say it isn't a permission issue if you can access it by IP. The binding is more likely. I don't deal with a ton of IIS and I don't if there are others on here. You may want to pose your question specifically on an IIS forum.
This will probably be the best place to ask.
IIS.NET Forums : The Official Microsoft IIS Forums
