vintagesierra
- Joined
- Jan 19, 2009
- Messages
- 10
- Thread Author
- #1
I am trying to boot GParted Live CD from the .iso file I burned to a cd. I have went in and changed my BIOS settings and it still won't boot to the cd, so therefore I can't figure out a way to partition my hard drive. I do have two hard drives though, the main C drive I wanted to install Windows 7 on but I also have a separate hard drive for my media which has a lot more space. I have only backed up the C drive, not the media drive, as the media drive has a lot to back up. I have downloaded different versions of GParted Live CD, burned it to different cds, and still nothing works. So if I cannot fix this, which I really want to, is it going to be a big problem installing Windows 7 on my media drive that won't have any separate partitions for it? I just really wanted to dual boot from my main drive but I can't figure out how.
- Joined
- Nov 10, 2008
- Messages
- 1,638
vintagesierra
- Joined
- Jan 19, 2009
- Messages
- 10
- Thread Author
- #3
I'm new to this, so how do I get to disk management and then format it in ntfs? I don't have the fastest internet so I'm doing the best I can trying not to load every website on the planet to find the answers so thanks for the fast reply.
Ok I have found the disk management. When I right click my C hard drive, there is no option to shrink. The file system is already NTFS and I can't click format or anything from there.
Well, I figured out how to do it, for now I was able to do everything with Windows 7's DiskPart and didn't have to figure out why GPartEd won't work. I guess that will be for later.
Similar threads
- Replies
- 5
- Views
- 2K
- Replies
- 2
- Views
- 3K
- Replies
- 2
- Views
- 1K
- Solved
- Replies
- 1
- Views
- 1K
