Windows 7 Programs won't open unless i run them in compatibility mode.
Uynn
Some programs on my computer won't open unless i put the program into compatibilty mode. is there anyway to fix this?
Hmm.. What anti virus product or products are you using? I see that nearly all those apps connect to the net and I wonder if your security is getting in the way?
Hi Llynn,
I guess it depends on the actual programs used? Have you tried using updated versions or isn't that possible? Can you list which programs are giving you this issue, thanks.
Hi Llynn,
The programs is fully updated and i have trouble with most of the programs downloaded.
The programs that are troubling me currently or Curse Voice, steam, Battle net, and Skype they work but only if i put them in compatibility mode.
