Windows 7 Question about Processors and 7
spada
In winXP you can support 2 processors, being 1 dual core, or 2 single cores... etc. Have they increased this at all? Is that only 2 physical, so you can actually use a dual quad core system (8 processors, but only 2 physical still). Any ideas? Documentation?
In Windows XP, the support for multiple processors was limited compared to newer versions of Windows. Here's a breakdown of the processor support in different versions of Windows: 1. Windows XP: - Windows XP Professional supported up to two physical processors. - It could also support both single-core and dual-core processors, including scenarios like one dual-core processor or two single-core processors. - Windows XP Professional x64 Edition, which was specifically designed for 64-bit processors, also supported up to two physical processors. 2. Windows 7: - Windows 7 Professional, Enterprise, and Ultimate editions supported up to two physical processors. - The support for processor cores varied based on the edition: -...
In Windows XP, the support for multiple processors was limited compared to newer versions of Windows. Here's a breakdown of the processor support in different versions of Windows: 1. Windows XP: - Windows XP Professional supported up to two physical processors. - It could also support both single-core and dual-core processors, including scenarios like one dual-core processor or two single-core processors. - Windows XP Professional x64 Edition, which was specifically designed for 64-bit processors, also supported up to two physical processors. 2. Windows 7: - Windows 7 Professional, Enterprise, and Ultimate editions supported up to two physical processors. - The support for processor cores varied based on the edition: - Windows 7 Home Basic and Home Premium: Support for one physical processor package (CPU) - Windows 7 Professional and Enterprise: Support for up to two physical processors - Windows 7 Ultimate: Support for up to two physical processors 3. Windows 8 and 10: - Windows 8 and Windows 10 have increased the support for multiple processors: - Windows 8: Support for up to two physical processors for the standard editions - Windows 8 Pro and Enterprise: Support for up to two physical processors with additional features - Windows 10: Typically supports up to two physical processors for most editions 4. Windows Server Operating Systems: - Windows Server editions have had higher support for processors compared to client versions. For example, Windows Server 2019 supports up to 64 physical processors. If you are looking to utilize a system with a configuration like a dual quad-core setup (8 processors), you would generally be looking at a server-grade operating system like Windows Server rather than Windows XP or even Windows 7. For specific details and documentation on processor support in different versions of Windows, you can refer to Microsoft's official documentation, such as the Windows Hardware Compatibility List (HCL) or system requirements for each Windows version. If you need more specific details or documentation references for a particular Windows version, let me know!
