Windows 7 Questions re: using Skype on my netbook with lid closed
cook
I want to use Skype on my netbook with the lid closed and need help with appropriate settings:
1) I set closing the lid when on battery to do nothing. (My netbook is in my briefcase and the lid must stay closed)
2) Do I need to set sleep settings? I'm fine with it going to sleep if Skype will wake it in time for me to answer the phone.
3) I want to use voice commands to control Skype. Is there anything tricky in that?
Thank you.
2. You need Wake-on-LAN - Wikipedia, the free encyclopedia if it's implemented on your motherboard and if Wake-on-LAN must be enabled in the Power Management section of a PC motherboard's BIOS setup utility.
Intel to Add Wake-on-VoIP Technology to Mobos - News and Analysis by PC Magazine
In theory, you can achieve the same with an external device if it is properly recognized in bios and if the bios has the option "Wake up on external device interruption".
3. As for controlling Skype with voice, check there:
Link Removed - Invalid URL
UmeSkype - Use your voice to control Skype!
