Reduce Motion and Animation in Windows 10/11 for Faster, Easier Navigation​
Difficulty: Beginner | Time Required: 10 minutes
Windows looks polished thanks to fading menus, sliding panels, and animated effects—but not everyone enjoys them. For some users, motion effects can feel distracting, make navigation seem slower, or even trigger eyestrain, dizziness, or motion sensitivity. The good news is that Windows 10 and Windows 11 both include built-in accessibility settings that let you reduce or disable many of these animations.
In this tutorial, we’ll walk through the easiest ways to reduce motion in Windows so your PC feels simpler, calmer, and easier to use.
Why reduce motion?​
Turning off unnecessary animations can help by:
Quick walkthrough
  • Making menus and windows appear more quickly
  • Reducing visual distractions
  • Improving comfort for users with motion sensitivity
  • Making navigation feel more direct and predictable
  • Slightly improving responsiveness on lower-end hardware
Prerequisites​
Before you begin, make sure:
  • You are signed in to a Windows 10 or Windows 11 account
  • You have permission to change Settings on the PC
  • You know which version of Windows you’re using
Note:
Windows 11 uses the Accessibility section in Settings, while Windows 10 often uses Ease of Access. The feature is similar, but the menus are named a little differently.
Step-by-step: Reduce motion and animation in Windows 11​
If you are using Windows 11, follow these steps:
  • Click Start and open Settings.
    You can also press Windows key + I to open Settings quickly.
  • In the left pane, click Accessibility.
  • Scroll down and select Visual effects.
  • Find the option called Animation effects.
  • Switch Animation effects to Off.
Windows 11 Accessibility Visual effects page showing the Animation effects toggle turned off.
That’s it. Windows will immediately reduce many common animations, including effects used when opening menus, switching windows, and interacting with parts of the interface.
Optional: Reduce transparency too​
If you want an even calmer, cleaner interface:
  • Stay in Settings > Accessibility > Visual effects
  • Turn Transparency effects to Off
Windows 11 Accessibility Visual effects page showing the Transparency effects toggle turned off.
This removes some of the see-through blur effects used in menus, taskbar areas, and windows.
Tip:
Turning off transparency won’t directly disable motion, but many users find it makes the desktop feel cleaner and easier on the eyes.
Step-by-step: Reduce motion and animation in Windows 10​
If you are using Windows 10, the setting is in a slightly different place.
    Or press Windows key + I.
  • Click Ease of Access.
  • In the left menu, click Display.
  • Scroll down to the Simplify and personalize Windows section.
  • Find Show animations in Windows.
  • Switch it Off.
Windows will stop using many built-in interface animations after you change this setting.
Optional: Turn off transparency in Windows 10​
You can also reduce visual effects further:
  • Open Settings
  • Go to Personalization
  • Click Colors
Advanced option: Disable extra visual effects for even less animation​
If you want to go further than the main Accessibility setting, Windows also includes a classic performance menu with more visual effect controls.
These steps work in both Windows 10 and Windows 11.
  • Press Windows key + S and type Advanced system settings.
  • Click View advanced system settings.
  • In the System Properties window, under the Advanced tab, look for the Performance section.
  • Click Settings.
  • In the Performance Options window, you have a few choices:
  • Let Windows choose what’s best for my computer
  • Adjust for best appearance
  • Adjust for best performance
  • Custom
  • For the biggest reduction in effects, choose Adjust for best performance.
  • Click Apply, then OK.
This disables many visual flourishes, including window animations, fades, and some shadows.
Warning:
Using Adjust for best performance can make Windows look more basic. Some users prefer to choose Custom instead so they can keep a few visual elements they like.
Recommended custom settings​
If you choose Custom, you can leave useful items enabled while turning off the more distracting ones. Look for options such as:
  • Animate controls and elements inside windows
  • Animate windows when minimizing and maximizing
  • Fade or slide menus into view
  • Fade or slide ToolTips into view
  • Show shadows under windows
Unchecking these can make Windows feel snappier and reduce motion without making the interface look too plain.
How to tell if the changes worked​
After making the changes, try these quick tests:
  • Open the Start menu
  • Open and close File Explorer
  • Minimize and restore a window
  • Open Quick Settings or Action Center
  • Switch between apps using Alt + Tab
You should notice fewer fades, slides, and zoom-style transitions.
Troubleshooting tips​
If you still see animations, try the following:
1. Restart your PC​
Some effects update immediately, but a restart can help ensure all changes take effect.
2. Check both Settings and Performance Options​
The Accessibility/Ease of Access setting controls major animations, but the advanced Performance Options menu can still contain extra effects.
3. Check graphics utility software​
Some manufacturer tools from Intel, AMD, or NVIDIA may influence desktop visuals. This is less common, but worth checking if behavior seems unusual.
4. Make sure Windows is updated​
Some menu paths and labels can change slightly between Windows builds.
Note:
On newer Windows 11 releases, the main path is usually Settings > Accessibility > Visual effects.
On Windows 10, it is usually Settings > Ease of Access > Display.
Extra accessibility suggestions​
If reducing motion helps, you may also benefit from a few related settings:
Turn off transparency​
Less visual clutter, especially around menus and taskbar areas.
Increase text size​
In Windows 11: Settings > Accessibility > Text size
In Windows 10: Settings > Ease of Access > Display
Use contrast themes​
Helpful if interface elements feel harder to distinguish once effects are removed.
Make the mouse pointer easier to see​
A larger or higher-contrast pointer can improve navigation comfort.
Who should use this setting?​
Reducing motion is especially helpful for:
  • Users with vestibular sensitivity
  • Anyone who feels dizzy or uncomfortable with animations
  • People who prefer a cleaner, faster-looking desktop
  • Users on older or lower-powered PCs
  • Anyone who wants fewer visual distractions while working
Even if you do not consider yourself an accessibility user, this setting can still make Windows feel more efficient.
Reducing motion and animation in Windows 10 or Windows 11 is one of the fastest ways to make the desktop feel calmer, simpler, and sometimes quicker. With just a few clicks, you can turn off many of the fades and sliding effects that make navigation feel busy or uncomfortable. If needed, the advanced performance settings let you go even further.
For many users, this small tweak makes everyday tasks—opening menus, switching apps, and moving around Windows—much easier.
Key Takeaways:
  • Turning off animation effects can make Windows feel faster and less distracting
  • Windows 11 uses Accessibility > Visual effects, while Windows 10 uses Ease of Access > Display
  • You can reduce motion further with Advanced system settings > Performance
  • Disabling transparency can also make the interface easier on the eyes
  • This setting is especially useful for motion sensitivity, focus, and easier navigation
This tutorial was generated to help WindowsForum.com users get the most out of their Windows experience.
