Regatta Hillpack Insulated Jacket: Water Repellent Warmth Not Waterproof
Regatta’s Hillpack line promises the sort of everyday outdoor utility that sells well: lightweight warmth, easy packability, and a fabric that resists bad weather—but the distinction between water‑repellent and waterproof, and the many variations within the Hillpack family, matter a great deal if you’re buying this jacket for serious hillwalking rather than commuting on a damp day.
Man in a blue rain jacket stands on a misty mountain trail with a navy Regatta pack and gray backpack.Background / Overview​
Regatta’s Hillpack series is a recurring staple in the brand’s women’s outerwear range. Across the Hillpack II, Hillpack IV and related iterations you’ll find the same core concept: a very lightweight, 20‑denier polyamide shell treated with a Durable Water Repellent (DWR) finish, filled with Feather Free synthetic insulation and designed to compress or pack away when not in use. The garments show up across multiple retailers and market channels as affordable, entry‑level insulated jackets aimed at hikers, travelers and everyday users who want a low‑bulk, warm layer that sheds light drizzle.
What’s prompted renewed interest is a flurry of third‑party listings describing the jacket with terms like “lightweight waterproof” and colour finishes labelled as “enamel.” Those short product blurbs are useful as marketing copy, but they conflate industry terms in ways that can mislead the buyer. This feature dissects the Hillpack proposition, verifies the technical claims where possible, highlights strengths, explains the limitations, and suggests alternatives for buyers with different weather needs.
Design and Materials: What the Hillpack is actually made of​
Shell fabric and weight​
The Hillpack jackets are built on a lightweight 20D polyamide face fabric. Regatta’s product descriptions list a fabric weight of around 37 g/m² for the shell in several Hillpack II/IV variants—this is thin, lightweight nylon/polyamide designed to be packable, not a workhorse outer for prolonged heavy weather.
Insulation​
Rather than real down, the Hillpack uses Regatta’s Feather Free synthetic insulation—marketed as premium recycled synthetic down, typically specified at ~60 gsm fill in the Hillpack II/IV models. Synthetic fill like this offers warmth without bulk and retains more insulating performance if it gets damp than untreated natural down, though it will still lose loft when heavily soaked. Multiple retailer product pages repeat these basic numbers across the Hillpack line.
Finish and appearance​
The “enamel finish” description seen in some advertising appears to be a colour/finish descriptor used by third‑party listings rather than an official technical term on Regatta’s product pages. Regatta’s own product pages describe the outer as having a Durable Water Repellent (DWR) finish, not an enamel coating. When sellers use terms like “enamel finish” they’re most often referring to a glossy look or the particular colourway a retailer lists, not an actual enamel coating comparable to paint or metal enamelling. I could not find any technical reference from Regatta that uses the phrase “enamel finish” to describe Hillpack fabrics. This suggests the phrase is marketing shorthand rather than a verified material treatment. Treat that wording cautiously.
Waterproof vs Water‑Repellent: the critical distinction​
One of the most important technical clarifications for prospective buyers: the Hillpack is water‑repellent, not fully waterproof. Regatta classifies the Hillpack variants as having a durable water‑repellent finish, and multiple retailers echo the same: the jackets will cause light rain to bead and roll off the outer surface, but they do not offer taped seams, Isotex membranes, or hydrostatic ratings that define true waterproof garments. In short: great for drizzle, poor for prolonged heavy rain.
Why this matters:
  • DWR is the first line of defense but is not a waterproof membrane—when DWR wears off the shell will “wet out” and soak through under continued exposure. Regatta explains that DWR alone does not make a jacket waterproof and should be seen as a surface treatment that complements true waterproof systems. Outdoor authorities and technical guides agree: DWR helps fabrics shed water in light showers but doesn’t equal a waterproof, taped‑seam shell.
Practical implication: if your idea of “waterproof” is a jacket you can rely on in a prolonged, wind‑driven downpour on the hill, the Hillpack is not that jacket. If you want a compact, warm, quick‑packable insulated layer that handles light showers and spits of rain while keeping weight and cost down, the Hillpack is appropriate.
Construction details and features​
  • Pockets: typical Hillpack models include two zipped lower pockets. Zips are usually concealed or standard—expect the security and convenience of zipped lower pockets but not necessarily waterproof zippers.
  • Hood: some Hillpack versions are hoodless (body/puffa styles), while Hillpack II/IV variants may have a grown‑on hood. Check the specific product SKU.
  • Compressibility / packability: the jacket is deliberately designed to be compressible—specific models often pack into themselves or a small stuff sack, which is a genuine convenience for travel and day hikes.
  • Cuff and hem finish: stretch binding on cuffs/hem and elasticated hood openings are common, improving fit and reducing drafts for casual use.
  • Care: most Hillpack variants are machine washable and described as easy‑care, but because DWR can be degraded by harsh detergents and wear, following technical wash advice is recommended. Regatta and technical care guides explain how washing and heat can reactivate some DWRs, and when to consider re‑proofing.
Performance: warmth, breathability and weather protection​
Warmth-to-weight​
For a 60 gsm synthetic fill and a minimal shell, the Hillpack delivers a respectable warmth-to-weight ratio suitable for three‑season hillwalking in temperate climates or as a mid‑layer under a waterproof shell in colder conditions. The compact synthetic fill gives a “puffa” feel without the bulk of heavy parkas.
Breathability and active use​
Because Hillpack jackets typically lack a breathable waterproof membrane, extended high‑output activities where you sweat heavily (fast uphill walking, scrambling with a pack) can leave you feeling damp from the inside even if the outside beads rain. For active users the right setup is layering: wicking base, light insulating mid‑layer (Hillpack if used), and a proper waterproof shell for sustained rain.
Wet weather behavior​
  • Short light showers: DWR is effective at beading water away, so you’ll stay dry long enough for a quick break or short exposed ramps.
  • Prolonged rain or heavy, wind‑driven showers: the DWR will eventually wet out; without a membrane and taped seams the jacket will allow water penetration. That’s the difference between “resists rain” and “keeps you dry for hours.”
Fit & sizing — what Size 12 means and why “fits true to size” is subjective​
Retail listings for Regatta jackets show standard UK sizing; a UK size 12 typically corresponds to a chest measurement around 108 cm in Regatta’s jacket tables and is often labelled as Medium in international conversion charts. Regatta and multiple retail partners maintain size charts that let you compare bust/chest and sleeve lengths—use those charts rather than assuming “size 12 fits the same across brands.”
A few practical points:
  • Layering allowance: Hillpack’s cut is generally a modern, regular fit—there is some room for a light midlayer but not a bulky base + heavy fleece.
  • Hooded vs non‑hooded models: hooded versions can feel different in collar fit and should be tried on if possible.
  • “True to size” claims: statements like “Size 12 fits true to size” are inherently subjective and vary by body shape. They appear frequently in retail copy and user reviews, but the only objective step is to measure chest/height and match Regatta’s published measurements.
Sustainability and care: what Regatta says​
Regatta markets the Hillpack with an eco angle: the Feather Free insulation is made from recycled materials (the company often points to recycled polyester sourced from post‑consumer plastic bottles as a feedstock). Regatta also states that its DWR treatments are PFC‑free from late 2020 onward—reflecting an industry shift away from long‑chain PFAS in many brands’ DWR formulations. These are positive steps, though they can affect long‑term DWR durability and effectiveness compared with older fluorocarbon finishes.
Care guidance:
  • Prefer technical detergents that preserve DWR performance and avoid fabric softeners.
  • Some DWR performance can be renewed by heat activation (tumble drying on low where the garment care label allows) or with specific spray‑on or wash‑in reproofing products if the fabric begins to wet out. Outdoor care guides explain the reproofing process in detail.
Value proposition: price, availability and comparisons​
One of the reasons Hillpack is popular is price. Retailers often run heavy discounts: examples in the market show the Hillpack II available for very low price points during sales events, positioning it as a budget, travel‑friendly insulated jacket. However, price is not the only measure of value: the key question is whether the jacket matches your intended use.
Compare Hillpack to:
  • A true waterproof shell (Isotex / Gore‑Tex / Pertex Shield): these offer prolonged rain protection, seam taping, and hydrostatic head ratings—expect significantly higher price and slightly more weight.
  • A lightweight down jacket: better compressibility and warmth-to-weight when extremely dry, but natural down performs poorly when wet unless hydrophobic treated.
  • Other synthetic packable puffas: many competitors offer similar specifications; Hillpack’s edge is Regatta’s distribution and consistent feature set across retailers.
Real‑world use cases: when the Hillpack shines — and when it fails​
Ideal uses
  • Urban commuting when showers are brief and infrequent.
  • Weekend travel and tourism—packability and low weight make it convenient for plane or city trips.
  • Short day hikes in mild conditions where warmth and light rain resistance are needed.
  • Layering under a proper waterproof shell in colder, wet conditions.
When to look elsewhere
  • Multi‑day hiking in areas with extended rain: choose a fully waterproof jacket with taped seams and a breathable membrane.
  • Cold, wet climbs where insulation must stay dry: pick treated down or a high‑performance synthetic that’s designed for wet insulative performance.
  • If you need technical features like pit zips, waterproof zips, or high hydrostatic head ratings—Hillpack is not targeted at that market.
Testing notes and caveats (what I could and couldn’t verify)​
Verified facts:
  • Material spec (20D polyamide, ~37 g/m² shell; ~60 gsm synthetic insulation) and DWR finish are stated consistently in Regatta product listings and multiple retailers.
  • The Hillpack is described as water‑repellent (DWR) on Regatta pages; Regatta explicitly differentiates DWR from a waterproof membrane in its own DWR explainer.
  • Packability, zipped pockets, stretch binding and feather‑free synthetic fill are consistent features repeated across official and retail pages.
Unverifiable or ambiguous claims:
  • The term “enamel finish” used by a third‑party listing is not a Regatta technical term for the Hillpack fabric. I could not find any official Regatta product page that uses “enamel finish” as a material or performance descriptor for Hillpack jackets; the phrase likely reflects a marketing colour name or an individual seller’s phrasing. Treat “enamel finish” as a cosmetic descriptor only unless the seller provides more detail.
  • Claims that the Hillpack is waterproof are contradicted by the manufacturer’s DWR‑based descriptions and are therefore misleading for buyers who expect taped seams and membrane protection. Several reseller pages occasionally label the product “waterproof,” which appears to be inaccurate or sloppy copy. Always default to the manufacturer’s technical spec for performance claims.
Practical buying checklist: How to decide if a Hillpack is right for you​
  • Purpose: Are you buying a lightweight insulating midlayer or do you need a primary rain shell? If the former, Hillpack qualifies. If the latter, pick a waterproof model.
  • Weather: For short, intermittent showers the Hillpack’s DWR will do the job; for sustained rain, choose an Isotex/membrane jacket.
  • Sizing: Use Regatta’s size chart measurements (bust / chest / length) to compare with your body measurements and layering needs—don’t rely solely on “fits true to size” marketing lines.
  • Care: Plan to reproof the DWR after repeated washing or heavy use to maintain water beading performance. Technical washes and periodic re‑proofing extend the usable life of the DWR finish.
  • Features: If you need hood adjusters, waterproof zips, pit zips, or long cut for better coverage, verify the exact Hillpack SKU you’re buying—some Hillpack variants (II vs IV) differ by hood and pockets.
Alternatives and upgrades​
If you like Hillpack’s packability but want stronger rain protection, consider a two‑piece approach:
  • Buy a lightweight insulating Hillpack‑style midlayer for warmth and packability, and pair it with a compact waterproof shell (look for taped seams and at least 5,000–10,000 mm hydrostatic head for general outdoor use).
  • If you prefer one jacket that does both, look at Regatta’s Isotex‑lined models or other brands’ waterproof‑insulated jackets—these will cost more but are designed for hours of rain rather than minutes. Regatta’s Reinna and Pack‑It lines are examples of jackets with Isotex membranes and taped seams for true waterproof performance.
Final verdict​
Regatta’s Hillpack jackets deliver exactly what their core specification promises: a lightweight, warm, packable insulated jacket with a DWR finish that resists light rain. For city commuters, travellers and casual hillwalkers who want a no‑fuss, inexpensive insulated layer that packs small and looks good, the Hillpack is a compelling option.
However, the Hillpack is not a fully waterproof shell. If you were drawn to the product by phrases like “lightweight waterproof jacket” or the colourful marketing term “enamel finish,” be aware that those descriptions do not alter the Hillpack’s technical classification as DWR‑treated insulated outerwear. Buyers who need confident rain protection in sustained, windy downpours should upgrade to a true waterproof jacket with taped seams and a waterproof membrane, or adopt a layered approach with a waterproof shell over a packable insulated midlayer.
In short: buy the Hillpack for lightweight warmth and convenience; buy a membrane shell if you need full wet‑weather protection. Keep an eye on DWR care and reproofing to preserve the jacket’s performance, and check the specific Hillpack SKU for hood, pocket and fit differences before you buy.
Conclusion: Regatta’s Hillpack earns high marks for value, packability and casual weather resistance—but it should be sold and bought as a water‑repellent insulated layer, not a long‑haul waterproof jacket.
Source: ruhrkanal.news https://ruhrkanal.news/s-Hillpack-Lightweight-Waterproof-Jacket-Enamel-Finish-Size-1133934/
