In Microsoft’s terminology, the phrase “Remote Code Execution” in the CVE title describes the impact of the bug, not necessarily the CVSS attack vector. In other words, if the vulnerability is successfully triggered, the attacker can cause code to run on the victim’s machine, but the exploit path may still require local processing of a file, document, or other payload. Microsoft has used this pattern for years in Word-related advisories and similar Office issues, where a victim opens or renders content locally and the result is arbitrary code execution in the context of the application.
So the apparent contradiction is mostly about two different classification systems:
- CVE title / Microsoft advisory wording: focuses on what the vulnerability can achieve — remote code execution, arbitrary code execution, or elevation of privilege.
- CVSS AV:L: focuses on the attack vector, meaning the exploit requires local interaction or local execution context on the target system.
So the short answer is: the title is about the outcome; CVSS AV:L is about the required trigger path. Both can be true at the same time.
