Remote Code Execution vs CVSS AV:L: How Microsoft CVE Titles Differ
Infographic showing remote code execution: CVE title and “victim processes locally” with MSRC terminology mismatch.
The short answer is that “Remote Code Execution” in Microsoft’s CVE title describes the impact class, not necessarily the CVSS attack vector. Microsoft’s own guidance and long-standing MSRC usage show that a vulnerability can be labeled RCE even when exploitation requires local user interaction or a local trigger path; the title tells you what an attacker can ultimately achieve, while the CVSS vector tells you how the attack is initiated and under what constraints. In other words, remote refers to the fact that the code runs on the victim’s machine, not that the attacker must be on the network in a fully remote, unauthenticated sense.
For CVE-2026-33115, the “remote” label is best read as shorthand for arbitrary code execution on a distant target system after a successful exploit chain, while AV:L indicates the attacker must first get a malicious file, object, or local execution context into play on that machine. That combination is not unusual in Microsoft Office cases. MSRC has previously described Office-triggered RCE issues where the vulnerable code executes when a user opens a crafted document, meaning the exploit begins with a local action but ends with code execution in the context of the affected application.
So the apparent contradiction is mostly a terminology mismatch. CVSS is precise about the attack path; Microsoft’s product-title wording is broader and more user-facing. The result is that a vulnerability can be remotely weaponized through email, downloads, shared files, or collaboration tools, yet still score as local because the decisive moment happens when the victim opens or processes the content on the local machine.
If you want the cleanest interpretation, use this rule of thumb:
  • CVE title: tells you the security outcome Microsoft is warning about.
  • CVSS AV:L: tells you the exploit needs local execution or local user action.
  • Real-world delivery: can still be remote, because the malicious content is often sent from afar and only detonates locally.
Your paraphrase is broadly correct, with one refinement: it is not necessarily that the attacker must “execute code from the local machine” manually. More precisely, the attacker typically needs the victim to open, preview, or otherwise process a malicious file locally, and that local processing then leads to code execution on the victim system. That is why Microsoft can legitimately call it Remote Code Execution even when CVSS says Local.
