variskarhu
i have this little problem with remote desktop.
Link Removed due to 404 Error
check out that picture attached. As you can see there are two "System Properties" side by side left one is mine (language is finnish) and right one is copied from "how to set up remote desktop." Every single "how to set up remote desktop" guide looks like that and i have no idea why my system properties doesnt look the same. Do i need somekind of program or something to make it work? (I have windows 7 home edition)
Your versions of Windows 7 does not support hosting remote desktop sessions. In order to do that, you would need Windows 7 Professional, Enterprise or Ultimate. I believe you can still use the client piece to connect to other machines that are capable of hosting remote desktop sessions, but your machine cannot be the host.
Hope this helps
Randy
Hope this helps
Randy
Yeah it helped alot thanks so much. But now im pretty sad coz i bought stupid home edition...
Well otherwise those programs would be good but im trying to get my htc hd 2 desktop remote working. So i cant use any of those programs. Thanks anyway. =)
