Right Click
A right click no longer brings up a dialog box, is there some way to enable this feature?
Saltgrass
If you go to the Start globe and right click to select properties, customize, there is a Enable Context menus and dragging and dropping. Do you have that checked?
Has your system been normal until recently and do you know of anything that might have changed?
