AMD’s Ryzen 7 5800X3D 10th Anniversary Edition has reached UK retailers, restoring a high-end gaming upgrade option for existing AM4 systems. OC3D reported July 15 that Amazon UK, Overclockers UK and Scan were listing the chip at £314.99; Overclockers UK showed stock at publication time.
This is not a new architecture or a faster revision. AMD has reissued the 2022-era Ryzen 7 5800X3D to mark 10 years of the AM4 platform, using the same eight-core, 16-thread Zen 3 design: 3.4GHz base clock, up to 4.5GHz boost, 96MB of L3 cache, and a 105W TDP. AMD lists support for Windows 10 and Windows 11, DDR4 memory, PCIe 4.0, and AM4 boards based on X570, X470, B550, B450 and A520 chipsets.
The practical appeal is simple: a user with a compatible Ryzen 1000-, 2000-, 3000-, or non-X3D 5000-series system can retain their motherboard and DDR4 memory while moving to the strongest gaming-focused CPU AMD offers for socket AM4. The large 3D V-Cache pool remains particularly useful in games that are sensitive to memory latency and CPU cache capacity.
That does not automatically make it the best purchase for every builder. At roughly £315, the 5800X3D carries a late-platform premium, and its price must be weighed against current AM5 processor, board, and DDR5 bundle costs. It also has no integrated graphics, so it requires a discrete GPU. Buyers primarily doing heavily threaded workstation work may find more cores or a newer platform more useful than the 5800X3D’s gaming-first cache configuration.
AMD’s official specifications also note that the processor is supplied without a cooler. The box includes a Carbice Ice Pad thermal interface rather than conventional paste; AMD says the carbon-nanotube pad is intended to simplify installation and provide a durable interface. A capable cooler is still required.
The relaunch is chiefly relevant to owners who want another few years from an otherwise healthy AM4 Windows gaming PC without replacing memory and motherboard.
An AM4 upgrade, not a new build bargain
The practical appeal is simple: a user with a compatible Ryzen 1000-, 2000-, 3000-, or non-X3D 5000-series system can retain their motherboard and DDR4 memory while moving to the strongest gaming-focused CPU AMD offers for socket AM4. The large 3D V-Cache pool remains particularly useful in games that are sensitive to memory latency and CPU cache capacity.That does not automatically make it the best purchase for every builder. At roughly £315, the 5800X3D carries a late-platform premium, and its price must be weighed against current AM5 processor, board, and DDR5 bundle costs. It also has no integrated graphics, so it requires a discrete GPU. Buyers primarily doing heavily threaded workstation work may find more cores or a newer platform more useful than the 5800X3D’s gaming-first cache configuration.
Check firmware before swapping
AM4 compatibility is broad, but it is not automatic. Motherboard vendors normally require a BIOS update before an older board will recognize the 5800X3D. Update the BIOS while the current, supported CPU is still installed, then check the vendor’s CPU support list for the exact board revision. Administrators and enthusiasts should also record existing BIOS settings, including TPM, Secure Boot, boot mode and memory profiles, before flashing firmware.The relaunch is chiefly relevant to owners who want another few years from an otherwise healthy AM4 Windows gaming PC without replacing memory and motherboard.
- Primary source: OC3D
Published: 2026-07-15T10:18:49+00:00
AMD's Ryzen 7 5800X3D returns to UK retailers - OC3D
AMD's Ryzen 7 5800X3D CPU has returned to UK retailers. AMD's top AM4 gaming CPU is now available in the UK.overclock3d.net - Related coverage: overclockers.co.uk
AMD Ryzen 7 5800X3D 10th Anniversary Edition Eight Core 4.5GHz (Socket AM4) Processor - Retail | OcUK
Order AMD Ryzen 7 5800X3D 10th Anniversary Edition Eight Core 4.5GHz (Socket AM4) Processor - Retail now online and benefit from fast delivery.www.overclockers.co.uk - Related coverage: tomshardware.com
- Related coverage: amd.com
AMD Ryzen™ 7 5800X3D ゲーミング プロセッサ
www.amd.com
- Related coverage: forums.pcgamer.com
- Related coverage: forums.overclockers.co.uk
AMD Ryzen 7 5800X3D 10th Anniversary Edition available from OcUK for £299 and LOWEST PRICES ON DDR4 IN THE UK !!! | Overclockers UK Forums
Hi there We have hundreds of AMD's latest 5800X3D 10th Anniversary 3D AM4 Processor, we have also worked hard to bring some incredible DDR4 deals and...forums.overclockers.co.uk
