Pcgamer27
Member
I am looking for a script that will execute this automatically
NinitePro.exe /select Chrome Safari Opera+ Edge Thunderbird+ Zoom Skype VLC /freeze Offline_Installer11.exe
NinitePro.exe /select ITunes Firefox Spotify HandBrake Audacity Quicktime MediaMonkey Krita /freeze Offline_Installer22.exe
You can easily automate your Ninite Pro installation with a simple batch (.cmd) script or a PowerShell script. This will execute your NinitePro commands silently and automatically.
Below is a ready-to-use batch script version, which is the most compatible method for Ninite CLI installs during deployment:
Batch Script Example
[USER=35331]@echo[/USER] off
REM ---- Automated NinitePro installs ---- REM First set of apps (saved as Offline_Installer11.exe)
NinitePro.exe /select Chrome Safari Opera+ Edge Thunderbird+ Zoom Skype VLC /freeze Offline_Installer11.exe REM Second set of apps (saved as Offline_Installer22.exe)
NinitePro.exe /select ITunes Firefox Spotify HandBrake Audacity Quicktime MediaMonkey Krita /freeze...
NinitePro.exe /select ITunes Firefox Spotify HandBrake Audacity Quicktime MediaMonkey Krita /freeze Offline_Installer22.exe REM Optionally, you can run the offline installer(s) after freeze completes
REM Offline_Installer11.exe /silent
REM Offline_Installer22.exe /silent
How to Use
  • Place NinitePro.exe in the same directory as the script, or add the full path to the executable.
  • Save the above as InstallApps.cmd (or any .bat/.cmd file).
  • Double-click to run, or call from your deployment/FirstLogonCommands/GPO, etc.
If you want to use PowerShell (PS1), here’s a direct version:
Start-Process -FilePath ".\NinitePro.exe" -ArgumentList "/select Chrome Safari Opera+ Edge Thunderbird+ Zoom Skype VLC /freeze Offline_Installer11.exe" -Wait
Start-Process -FilePath ".\NinitePro.exe" -ArgumentList "/select ITunes Firefox Spotify HandBrake Audacity Quicktime MediaMonkey Krita /freeze Offline_Installer22.exe" -Wait # Optionally run the generated Offline_Installer executables
# Start-Process -FilePath ".\Offline_Installer11.exe" -ArgumentList "/silent" -Wait
# Start-Process -FilePath ".\Offline_Installer22.exe" -ArgumentList "/silent" -Wait
Tips
  • Use full paths if calling from other folders (e.g., "C:\Deploy\NinitePro.exe").
  • Both scripts can be used in unattended deployments (place in <FirstLogonCommands>, as a GPO logon script, or embedded in MDT/SCCM task sequences).
  • You can also schedule via Task Scheduler for maximum flexibility.
Let me know if you'd like this packed for use in autounattend.xml, as a scheduled task for first login, or adjusted for your deployment structure!
